Decode my Hemi 4 speed stamping #1943221
11/01/15 09:22 PM
11/01/15 09:22 PM
N.E. Ohio
K
KillerBee Offline OP
K
N.E. Ohio
I believe this 18 spline transmission started as a late 60's Hemi box with later B/E body dual mount tail shaft added?
Re: Decode my Hemi 4 speed stamping [Re: KillerBee] #1943224
11/01/15 09:27 PM
11/01/15 09:27 PM
cudanut Offline
cudanut  Offline
no its a 1970 b or e body someone may be looking for so the tail is correct
Re: Decode my Hemi 4 speed stamping [Re: KillerBee] #1943233
11/01/15 09:34 PM
11/01/15 09:34 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Case is from a 1970 Barracuda or Cuda.
Re: Decode my Hemi 4 speed stamping [Re: Alaskan_TA] #1943262
11/01/15 10:15 PM
11/01/15 10:15 PM
USA
rftroy Offline
rftroy  Offline
USA
Why couldn't it be from a Challenger?
Also, an 18 spline wouldn't be in a Barracuda.
Bob
AAR 4-speed 3.91, Tor-Red;
70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy;
68 Formula S conv 383 4-speed 3.23, Electric Blue;
69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue;
78 Lil' Red Truck, Red;
70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
Re: Decode my Hemi 4 speed stamping [Re: KillerBee] #1943281
11/01/15 10:37 PM
11/01/15 10:37 PM
N.E. Ohio
K
K
N.E. Ohio
Very interesting...I guess I now have two 4 speed transmissions from 1970 Cuda's.
Thanks for the info guys.
I bought this transmission many many years ago and it was attached to this 11" bell housing which I assume is for 1968?
The transmission has worked flawlessly for many years in my 440 powered street/strip 1973 Challenger and now will probably find it's way into my 1971 R/T Challenger.
Barry or anyone else if you can find the original car it came from it obviously would be for sale, otherwise I'll keep it.
Re: Decode my Hemi 4 speed stamping [Re: rftroy] #1943285
11/01/15 10:45 PM
11/01/15 10:45 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Because it isn't.
If you assume it has never been apart before, but I try not to assume anything which is why I mentioned the case itself.
I added it to my database, so if the car shows up at some point I'll give you a shout for sure.
Re: Decode my Hemi 4 speed stamping [Re: Alaskan_TA] #1943305
11/01/15 11:01 PM
11/01/15 11:01 PM
N.E. Ohio
K
K
N.E. Ohio
Thanks Barry.
Can you verify this 23 spline E-body transmission was also from a 1970 'Cuda.
I pulled it many years ago from what looked like an original 340 drivetrain in a 1970 'Cuda heading off to the junkyard.
Add it to your list but I doubt the car is still around today but you never know.....
Re: Decode my Hemi 4 speed stamping [Re: KillerBee] #1943314
11/01/15 11:07 PM
11/01/15 11:07 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Already on the list, you have mentioned it before. :-)
Re: Decode my Hemi 4 speed stamping [Re: KillerBee] #1943322
11/01/15 11:13 PM
11/01/15 11:13 PM
Alabama
BigMoneyLewis Offline
Alabama
That first one looks like it would be from a car with an SPD around November 15th 1969 , that last one, wow, that's a late one , off the top of my head I'd guess mid July 70,
but that's a pure guess .
Greg
gregward@mchsi.com phone 256-852-0955
