Passenger Side shock with Hemi??? #1933540
10/16/15 11:45 PM
10/16/15 11:45 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
On a 64-65 B body do you need to cut and reverse the shock tower with a 426 Hemi???
Doug
MOPAR or NO CAR!!!
1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas
1964 Dodge Polara 582" Indy alum Block 426-1RA heads,
1933 Plymouth PE all Steel, LT1 4L60E
1959 Plymouth Savoy 33,000 mile survivor
Old cars are never done. They are ongoing projects!
Re: Passenger Side shock with Hemi??? [Re: 65 Hemi] #1933595
10/17/15 12:36 AM
10/17/15 12:36 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
I have always heard that was the case. Never tried it myself, though.
Re: Passenger Side shock with Hemi??? [Re: bobby66] #1933646
10/17/15 02:23 AM
10/17/15 02:23 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Just changed the stud mount to eyelet,welded 2 tabs under the shock tower.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Passenger Side shock with Hemi??? [Re: 65 Hemi] #1933678
10/17/15 09:40 AM
10/17/15 09:40 AM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
Thanks for the picture. Has anyone tried moving the engine over 1" to the drivers side. I'm running a rack, so no steering box.
Doug
MOPAR or NO CAR!!!
Re: Passenger Side shock with Hemi??? [Re: 65 Hemi] #1933756
10/17/15 12:57 PM
10/17/15 12:57 PM
ohio
hangemhigh Offline
hangemhigh  Offline
ohio
Yes you do. With the help of some reference pics, we'll be doing that to our '64 in the next few weeks. In the spirit of looking correct, it'll be inverted just as the factory cars were. I'll post some pics at that time if anybody is interested.
Re: Passenger Side shock with Hemi??? [Re: 65 Hemi] #1933860
10/17/15 06:05 PM
10/17/15 06:05 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
Thanks for the input. I'm just trying to find a solution because my engine compartment is done.
Doug
MOPAR or NO CAR!!!
Re: Passenger Side shock with Hemi??? [Re: hangemhigh] #1933914
10/17/15 08:49 PM
10/17/15 08:49 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Yes please, pics of the cut out piece before welding and how it's turned around. I have pics I took of one that was done, but not sure how it was sliced and diced.
Re: Passenger Side shock with Hemi??? [Re: 65 Hemi] #1933917
10/17/15 08:52 PM
10/17/15 08:52 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
What rate springs on coil overs? Got a pic of wheel side? Who's k-frame? Thanks, getting to that point on my 64 Savoy.
I think you'll need two bolts for bottom of wing mounts, track tech told me I needed two, grade 5 or better.
Re: Passenger Side shock with Hemi??? [Re: cudaman1969] #1933951
10/17/15 10:05 PM
10/17/15 10:05 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
I will take some pictures but Bob Pro Fab made the entire kit. He can guide you on spring rate. Search Bobs Pro Fab Mopar and it will come up.
Doug
MOPAR or NO CAR!!!
Re: Passenger Side shock with Hemi??? [Re: 65 Hemi] #1934199
10/18/15 11:57 AM
10/18/15 11:57 AM
s e mich
ro23car Offline
ro23car  Offline
s e mich
no you dont have to make it like an original unless you want it to look like one. mine was moved over 1 inch and i have no problems.
Re: Passenger Side shock with Hemi??? [Re: ro23car] #1934208
10/18/15 12:16 PM
10/18/15 12:16 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
What I wanted to hear, any problems with headers on driver side? Tunnel? I'm using a 4-speed so I can cut down the z-bar
Re: Passenger Side shock with Hemi??? [Re: cudaman1969] #1934221
10/18/15 12:35 PM
10/18/15 12:35 PM
s e mich
ro23car Offline
ro23car  Offline
s e mich
no but my headers are from dawson in california. they are slip togethers and i have an automatic.
Re: Passenger Side shock with Hemi??? [Re: ro23car] #1934232
10/18/15 12:58 PM
10/18/15 12:58 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
Thank you. What series do you race? Do you race NSS? Also do you have any pictures?
Doug
MOPAR or NO CAR!!!
Re: Passenger Side shock with Hemi??? [Re: ro23car] #1934270
10/18/15 01:55 PM
10/18/15 01:55 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Was the trans mount moved with it or was the engine/trans assembly "twisted", i.e. just the mounting moved over?
Re: Passenger Side shock with Hemi??? [Re: 65 Hemi] #1935413
10/20/15 04:46 AM
10/20/15 04:46 AM
s e mich
ro23car Offline
ro23car  Offline
s e mich
no nothing moved just moved the hole toward the outside of the car.
Re: Passenger Side shock with Hemi??? [Re: 65 Hemi] #1935581
10/20/15 03:04 PM
10/20/15 03:04 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I've had three 64s, my first in 68, last two, race cars. When doing the cage and frame on the one now I never realized how much the whole tunnel is moved over (front to back) to pass side. Learn something new every day i guess.
