Passenger Side shock with Hemi???
#1933540
10/16/15 11:45 PM
10/16/15 11:45 PM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
On a 64-65 B body do you need to cut and reverse the shock tower with a 426 Hemi???
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
Re: Passenger Side shock with Hemi???
[Re: bobby66]
#1933646
10/17/15 02:23 AM
10/17/15 02:23 AM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
Just changed the stud mount to eyelet,welded 2 tabs under the shock tower.
[Re: 65 Hemi]
#1933678
10/17/15 09:40 AM
10/17/15 09:40 AM
65 Hemi
San Diego CA
Thanks for the picture. Has anyone tried moving the engine over 1" to the drivers side. I'm running a rack, so no steering box.
Doug
[Re: 65 Hemi]
#1933756
10/17/15 12:57 PM
10/17/15 12:57 PM
Posts: 10 ohio
hangemhigh
ohio
On a 64-65 B body do you need to cut and reverse the shock tower with a 426 Hemi??? Yes you do. With the help of some reference pics, we'll be doing that to our '64 in the next few weeks. In the spirit of looking correct, it'll be inverted just as the factory cars were. I'll post some pics at that time if anybody is interested.
[Re: 65 Hemi]
#1933860
10/17/15 06:05 PM
10/17/15 06:05 PM
65 Hemi
San Diego CA
Thanks for the input. I'm just trying to find a solution because my engine compartment is done.
Doug
[Re: hangemhigh]
#1933914
10/17/15 08:49 PM
10/17/15 08:49 PM
Posts: 8,273 fredericksburg,va
cudaman1969
fredericksburg,va
On a 64-65 B body do you need to cut and reverse the shock tower with a 426 Hemi??? Yes you do. With the help of some reference pics, we'll be doing that to our '64 in the next few weeks. In the spirit of looking correct, it'll be inverted just as the factory cars were. I'll post some pics at that time if anybody is interested. Yes please, pics of the cut out piece before welding and how it's turned around. I have pics I took of one that was done, but not sure how it was sliced and diced.
[Re: 65 Hemi]
#1933917
10/17/15 08:52 PM
10/17/15 08:52 PM
cudaman1969
fredericksburg,va
Thanks for the input. I'm just trying to find a solution because my engine compartment is done. What rate springs on coil overs? Got a pic of wheel side? Who's k-frame? Thanks, getting to that point on my 64 Savoy. I think you'll need two bolts for bottom of wing mounts, track tech told me I needed two, grade 5 or better.
[Re: cudaman1969]
#1933951
10/17/15 10:05 PM
10/17/15 10:05 PM
65 Hemi
San Diego CA
Thanks for the input. I'm just trying to find a solution because my engine compartment is done. What rate springs on coil overs? Got a pic of wheel side? Who's k-frame? Thanks, getting to that point on my 64 Savoy. I think you'll need two bolts for bottom of wing mounts, track tech told me I needed two, grade 5 or better. I will take some pictures but Bob Pro Fab made the entire kit. He can guide you on spring rate. Search Bobs Pro Fab Mopar and it will come up.
Doug
[Re: 65 Hemi]
#1934199
10/18/15 11:57 AM
10/18/15 11:57 AM
Posts: 1,162 s e mich
ro23car
s e mich
no you dont have to make it like an original unless you want it to look like one. mine was moved over 1 inch and i have no problems.
[Re: ro23car]
#1934208
10/18/15 12:16 PM
10/18/15 12:16 PM
cudaman1969
fredericksburg,va
no you dont have to make it like an original unless you want it to look like one. mine was moved over 1 inch and i have no problems. What I wanted to hear, any problems with headers on driver side? Tunnel? I'm using a 4-speed so I can cut down the z-bar
[Re: ro23car]
#1934232
10/18/15 12:58 PM
10/18/15 12:58 PM
65 Hemi
San Diego CA
no you dont have to make it like an original unless you want it to look like one. mine was moved over 1 inch and i have no problems. Thank you. What series do you race? Do you race NSS? Also do you have any pictures?
Doug
[Re: ro23car]
#1934270
10/18/15 01:55 PM
10/18/15 01:55 PM
Posts: 11,579 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
no you dont have to make it like an original unless you want it to look like one. mine was moved over 1 inch and i have no problems. Was the trans mount moved with it or was the engine/trans assembly "twisted", i.e. just the mounting moved over?
[Re: 65 Hemi]
#1935581
10/20/15 03:04 PM
10/20/15 03:04 PM
cudaman1969
fredericksburg,va
I've had three 64s, my first in 68, last two, race cars. When doing the cage and frame on the one now I never realized how much the whole tunnel is moved over (front to back) to pass side. Learn something new every day i guess.
