I have a set of unknown manufacturer tublar A Arms im in the process of installing in my 62 valiant im upgrading the brake system from SBP KH setup to a LBP brake setup.
The arms i have have a poly mount that are dry rotted and need to be replaced before i install the arms im going to replace them with a heim joint end and im in need of the measurement of the spacers used in between the A arm ends and mounting ears on the frame that the eccentric bolts pass thru.
Any and all help is always appreciated
