I have a set of unknown manufacturer tublar A Arms im in the process of installing in my 62 valiant im upgrading the brake system from SBP KH setup to a LBP brake setup.
The arms i have have a poly mount that are dry rotted and need to be replaced before i install the arms im going to replace them with a heim joint end and im in need of the measurement of the spacers used in between the A arm ends and mounting ears on the frame that the eccentric bolts pass thru.
Any and all help is always appreciated
Check out my build on Facebook Ttoad Hurley its updated regularly
