The 911 is a pretty good universal spring for almost any off the shelf hydraulic, its more pressure than Lunati says you need, so its just a little more wear on parts, and a little higher risk of flattening a cam lobe, but its a negligible difference. TBH I would rather run those 911s than the Lunati springs on any cam, you don't want to/can't shim that spring up that much (thickest spring shim you will probably find to work will be .060), and I dont know if anyone make -.050 installed height locks. I'd keep the 911s, you'll be fine.
FYI I dont know what heads you've got but most stock and stock replacement heads are around 1.88-1.90 spring height.
