Hi,
I want to slightly upgrade the cam in my mild 493 stroker. I had all comp cams components (XE274L) but want to get a Lunati voodoo 60304/1023704 cam. Lunati suggests a single w/damper spring for their cam. Can anyone tell me if my current comp 911 springs will be ok? The specs seem similar.
I really want to stay with a single spring as I don't want to machine the heads.
Rocker ratio is 1.5, Comp Pro Magnum steel ones.
