Re: Instrument panel wire harness question
[Re: sixpackbird]
#1899493
08/26/15 12:14 AM
08/26/15 12:14 AM
Posts: 1,822 Colorado
denfireguy
Colorado
This wire is yellow without a tracer. It should be the power source for the title lamp, but I am not sure where it should connect to. The wire is part of the A01 light package. There is a bundle of wires that is tucked under the dash. In the middle of the bundle is an aluminum can that is the time delay. There should be a socket on a yellow wire there with two connections. One goes to the bulb over the headlight switch and the other goes to the bulb you are asking about. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
