Instrument panel wire harness question #1899405
08/25/15 10:40 PM
08/25/15 10:40 PM
South Carolina
sixpackbird Offline OP
South Carolina
Working on a 1971 Cuda rallye dash, where does the yellow wire from the steering column title lamp connect to the dash wire harness? Does anyone have a picture?
Re: Instrument panel wire harness question [Re: sixpackbird] #1899422
08/25/15 10:55 PM
08/25/15 10:55 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
What's a title lamp?
Re: Instrument panel wire harness question [Re: Pynzo] #1899436
08/25/15 11:15 PM
08/25/15 11:15 PM
South Carolina
South Carolina
The title lamp is a small bulb on the steering column next to the hazard lamp switch, not sure why its called a title lamp.
Re: Instrument panel wire harness question [Re: sixpackbird] #1899454
08/25/15 11:31 PM
08/25/15 11:31 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
My '70 Bee has an unused yellow wire w/ black tracer pigtailed into a female bullet connection near the fuse block that by my FSM wiring chart says is for Ignition Switch Lamp Ground. Maybe that's what you're looking for.
Re: Instrument panel wire harness question [Re: Pynzo] #1899477
08/25/15 11:58 PM
08/25/15 11:58 PM
South Carolina
South Carolina
This wire is yellow without a tracer. It should be the power source for the title lamp, but I am not sure where it should connect to.
Re: Instrument panel wire harness question [Re: sixpackbird] #1899493
08/26/15 12:14 AM
08/26/15 12:14 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
The wire is part of the A01 light package. There is a bundle of wires that is tucked under the dash. In the middle of the bundle is an aluminum can that is the time delay. There should be a socket on a yellow wire there with two connections. One goes to the bulb over the headlight switch and the other goes to the bulb you are asking about.
Craig
Re: Instrument panel wire harness question [Re: sixpackbird] #1899508
08/26/15 12:48 AM
08/26/15 12:48 AM
Shoreline, Washington
72roadrunnergtx Offline
The lamp, or lamps, would connect to a small harness for the time delay relay, that harness would in turn connect to female bullet connectors in the main dash harness, one for unswitched power (red three-way tap) and a single yellow with trace that is the left door switch ground circuit.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: Instrument panel wire harness question [Re: sixpackbird] #1899516
08/26/15 12:59 AM
08/26/15 12:59 AM
CT
1932chrysler Offline
CT
here is a photo
1932 Chrysler CI Sedan
1956 Pontiac Catalina Sedan
All Makes & Models Are Special
Re: Instrument panel wire harness question [Re: 1932chrysler] #1899527
08/26/15 01:18 AM
08/26/15 01:18 AM
CT
CT
another
Re: Instrument panel wire harness question [Re: 1932chrysler] #1900047
08/26/15 11:02 PM
08/26/15 11:02 PM
South Carolina
South Carolina
Thank you everyone for the information, this was extremely helpful. Thank you for the pictures 1932 Chrysler, those are a great help.
