Re: Pro gear sets longevity?
[Re: 451Mopar]
#1890583
08/12/15 10:00 PM
08/12/15 10:00 PM
Posts: 740 WA
JD Dart
WA
The Redline shock proof oil tuned to gel and killed the ring and pinion if you like it great! For me never again.
best so far 8.53 @ 158.59 MPH 60'1.240
[Re: 70satelliteguy]
#1890611
08/12/15 10:46 PM
08/12/15 10:46 PM
Posts: 19,385 Las Vegas
Al_Alguire
Las Vegas
Don't use Redline....
Pull it apart or the cover off and inspect them. They are just like any other gear, if you do not see any excessive wear or cracking then run them.
[Re: Al_Alguire]
#1890648
08/12/15 11:25 PM
08/12/15 11:25 PM
Posts: 939 glendora, ca.
Deepockets
glendora, ca.
Pull it apart or the cover off and inspect them. They are just like any other gear, if you do not see any excessive wear or cracking then run them. I haven't heard that about redline. How long has it been known that it's not what they say? I've been using it with my pro gear for at least 6 years. Now you've got me thinking to drain it. I might be "SHOCKED" in what I see! So what is the hot ticket for high h/p use?
#1890773
08/13/15 02:07 AM
08/13/15 02:07 AM
Al_Alguire
Las Vegas
I have seen it on a few different occasions.
As for what I use. Well we make ok power and we use whatever Napa sells, just that easy.
[Re: FastmOp]
#1890803
08/13/15 03:50 AM
08/13/15 03:50 AM
Posts: 4,291 Morrow, OH
markz528
Morrow, OH
Moser told me not to use synthetic gear oil. Said 80-90 gear oil Used Amsoil synthetic one time. Results were not good! Actually deformed the gears to the point of severe burrs on the edges of ring gear. Cleaned up the burrs and went back to the regular dino oil and those same gears were fine for a long time after that. Only dino stuff in rears and trannies for me from now on.............
