Pro gear sets longevity? #1890543
08/12/15 09:01 PM
08/12/15 09:01 PM
Penna
70satelliteguy Offline OP
Penna
Should I think about replacing my Richmond 4:10 Pro gear set?
10 years old,probably 500-600 transbrake launches at 4500 rpm. Low to mid 1.30 60 fts. 3660 B body.
Mike
Re: Pro gear sets longevity? [Re: 70satelliteguy] #1890546
08/12/15 09:05 PM
08/12/15 09:05 PM
WA
JD Dart Offline
JD Dart  Offline
WA
Is this 8-3/4 Dana 60 or ford 9"???
Re: Pro gear sets longevity? [Re: 70satelliteguy] #1890575
08/12/15 09:49 PM
08/12/15 09:49 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Have you tried the Redline Oil "Shock Proof" gear oil?
Re: Pro gear sets longevity? [Re: 451Mopar] #1890583
08/12/15 10:00 PM
08/12/15 10:00 PM
WA
JD Dart Offline
JD Dart  Offline
WA
The Redline shock proof oil tuned to gel and killed the ring and pinion if you like it great! For me never again.
best so far 8.53 @ 158.59 MPH 60'1.240
Re: Pro gear sets longevity? [Re: 70satelliteguy] #1890611
08/12/15 10:46 PM
08/12/15 10:46 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Don't use Redline....
Pull it apart or the cover off and inspect them. They are just like any other gear, if you do not see any excessive wear or cracking then run them.
Re: Pro gear sets longevity? [Re: Al_Alguire] #1890614
08/12/15 10:48 PM
08/12/15 10:48 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
iagree
Re: Pro gear sets longevity? [Re: Al_Alguire] #1890648
08/12/15 11:25 PM
08/12/15 11:25 PM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
I haven't heard that about redline. How long has it been known that it's not what they say? I've been using it with my pro gear for at least 6 years. Now you've got me thinking to drain it. I might be "SHOCKED" in what I see! So what is the hot ticket for high h/p use?
Re: Pro gear sets longevity? [Re: 70satelliteguy] #1890667
08/12/15 11:44 PM
08/12/15 11:44 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I haven't had issues with the redline oil, but my car is slower.
I used the blue "lightweight" gear oil in my 8-3/4 and did not have any problems. What caused it to gel? I never herd of that problem.
Re: Pro gear sets longevity? [Re: 451Mopar] #1890698
08/13/15 12:24 AM
08/13/15 12:24 AM
WA
JD Dart Offline
JD Dart  Offline
WA
I'd like to know, had Torco in it before.
Wanted to change from 4.30 to 4.56 that's when I went to the blue redline shockproof lube. The 4.56 didn't work out for throttle stop racing switched back to 4.30's when I pulled the drain plug it came out like blue tar wouldn't drain took 3 hrs to clean the housing.
May not happen to anyone else. But for me I had better things to do with my time.
Re: Pro gear sets longevity? [Re: 70satelliteguy] #1890773
08/13/15 02:07 AM
08/13/15 02:07 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I have seen it on a few different occasions.
As for what I use. Well we make ok power and we use whatever Napa sells, just that easy.
Re: Pro gear sets longevity? [Re: 70satelliteguy] #1890786
08/13/15 02:34 AM
08/13/15 02:34 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Moser told me not to use synthetic gear oil. Said 80-90 gear oil
Re: Pro gear sets longevity? [Re: FastmOp] #1890803
08/13/15 03:50 AM
08/13/15 03:50 AM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Used Amsoil synthetic one time. Results were not good! Actually deformed the gears to the point of severe burrs on the edges of ring gear. Cleaned up the burrs and went back to the regular dino oil and those same gears were fine for a long time after that.
Only dino stuff in rears and trannies for me from now on.............
