Re: Which piston Manufacurer?
[Re: DusterKid]
#1874669
07/20/15 10:48 PM
07/20/15 10:48 PM
Posts: 6,149 Melbourne , Australia
LA360
It comes down to what your budget is and what each manufacturer has as a shelf piston. CP and Diamond are nice, CP are a little pricey, but the quality is exceptional. Diamond are very good also. Wiseco are good bang for buck. Mahle is another piston I would look into.
Alan Jones
[Re: pittsburghracer]
#1874863
07/21/15 01:53 AM
07/21/15 01:53 AM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
The bore on my 408 in my duster right now is worn out at .030 so I found two sets of .060 over Wiseco pistons on sale that will be going in soon instead of my my diamond flat tops
[Re: DusterKid]
#1874960
07/21/15 11:02 AM
07/21/15 11:02 AM
Posts: 75,089 A Banana Republic near you.
JohnRR
I like Diamond , very nice pistons and if you need something semi custom they are easy to work with to make a couple of small changes , like moving the pin to where it needs to be which could be very important because aftermarket rods are SHORTER than original mopar rods by .008.
If you are trying to get a certain head to piston clearance and you are not paying attention and all of a sudden your .035 desire turns into .055 because the deck is not where it needs to be , the rods are shorter and your crank that was turned .010/.010 lost a little stroke ...
Measure EVERYTHING first before buying the pistons ...
[Re: DusterKid]
#1875005
07/21/15 12:13 PM
07/21/15 12:13 PM
Posts: 5,166 CT
GTX MATT
CT
The Wiseco Pro Trus in my 440 were 625 g each, and only cost around $500 and change. Nice pieces.
