Which piston Manufacurer? #1874595
07/20/15 09:30 PM
07/20/15 09:30 PM
Keymar, MD
DusterKid Offline OP
Keymar, MD
Is there any one manufacturer that is better than another when it comes to pistons? Currently I have stock rods and Speed Pro Hypereutectic pistons and am going to upgrade to Scat I beams and want a lighter piston to make a lighter rotating assembly. I see there's Ross, SRP, ICON (Which I guess is part of Keith Black?) and a few other makers.
Re: Which piston Manufacurer? [Re: DusterKid] #1874669
07/20/15 10:48 PM
07/20/15 10:48 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
It comes down to what your budget is and what each manufacturer has as a shelf piston. CP and Diamond are nice, CP are a little pricey, but the quality is exceptional. Diamond are very good also. Wiseco are good bang for buck. Mahle is another piston I would look into.
Alan Jones
Re: Which piston Manufacurer? [Re: LA360] #1874690
07/20/15 11:07 PM
07/20/15 11:07 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
I'd look into the Wiseco Pro-tru line of pistons. I picked up a set for my 408 rebuild, and they look like a nice piston, forged, and weigh 40 grams less per piston thank my diamonds I took out of that motor.
Re: Which piston Manufacurer? [Re: DusterKid] #1874824
07/21/15 12:48 AM
07/21/15 12:48 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
wiseco, cp and you might want to take a look at race tech pistons.
Re: Which piston Manufacurer? [Re: DusterKid] #1874828
07/21/15 12:53 AM
07/21/15 12:53 AM
AndyF Offline
AndyF  Offline
There is a piston listing in the tech archives for BB Mopar engines.
I just got these Diamond pistons today. Nice looking parts!
Re: Which piston Manufacurer? [Re: DusterKid] #1874848
07/21/15 01:29 AM
07/21/15 01:29 AM
P
Porter67 Offline
Porter67  Offline
P
I goto to plug wiseco as they have some nice stuff. Im using there 8cc domed pistons in two motors currently and used there stuff in the 80s in my snowmobiles.
Ive used most all brands and all have small differences that can work to your advantage if you research alot.
Vs some of the stroker slipper skirt designs, I do like the Ross slugs that have the full diameter approx 1/8 wide band? all the way around to lower portion of the skirt area. as for my it cut down of piston rock.
Re: Which piston Manufacurer? [Re: Porter67] #1874856
07/21/15 01:45 AM
07/21/15 01:45 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I like these Wiseco pistons i picked up for a 408 build one of these days.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Which piston Manufacurer? [Re: pittsburghracer] #1874863
07/21/15 01:53 AM
07/21/15 01:53 AM
PA.
"Little"John
"Little"John
PA.
The bore on my 408 in my duster right now is worn out at .030 so I found two sets of .060 over Wiseco pistons on sale that will be going in soon instead of my my diamond flat tops
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Which piston Manufacurer? [Re: DusterKid] #1874873
07/21/15 02:34 AM
07/21/15 02:34 AM
P
Porter67 Offline
Porter67  Offline
P
Maybe a pic? It worked!
I like those pistons alot.
I dont like adding to a websites pic database though.
Re: Which piston Manufacurer? [Re: DusterKid] #1874901
07/21/15 05:51 AM
07/21/15 05:51 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
I dropped a little coin on Diamond. The work is beautiful. I can't give a full report yet. But here is their work.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Which piston Manufacurer? [Re: DusterKid] #1874960
07/21/15 11:02 AM
07/21/15 11:02 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I like Diamond , very nice pistons and if you need something semi custom they are easy to work with to make a couple of small changes , like moving the pin to where it needs to be which could be very important because aftermarket rods are SHORTER than original mopar rods by .008.
If you are trying to get a certain head to piston clearance and you are not paying attention and all of a sudden your .035 desire turns into .055 because the deck is not where it needs to be , the rods are shorter and your crank that was turned .010/.010 lost a little stroke ...
Measure EVERYTHING first before buying the pistons ...
Re: Which piston Manufacurer? [Re: DusterKid] #1875005
07/21/15 12:13 PM
07/21/15 12:13 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
The Wiseco Pro Trus in my 440 were 625 g each, and only cost around $500 and change. Nice pieces.
