Headers, Big Block, Abody
#1871796
07/16/15 08:03 PM
07/16/15 08:03 PM
Posts: 147 pa. usa
wayne o
pa. usa
Anyone out there running headers on there Abody w/ a Big Block, that also has the fast ratio steering ? pitman arm, idler arm What headers are you running. TTI says no go, wont fit. I have 69 barracuda 383 4spd.
Re: Headers, Big Block, Abody
[Re: wayne o]
#1871881
07/16/15 09:39 PM
07/16/15 09:39 PM
Posts: 4,704 Wichita
GY3
Wichita
Anyone out there running headers on there Abody w/ a Big Block, that also has the fast ratio steering ? pitman arm, idler arm What headers are you running. TTI says no go, wont fit. B or RB?
[Re: wayne o]
#1872138
07/17/15 02:12 AM
07/17/15 02:12 AM
Posts: 43,305 Bend,OR USA
Cab_Burge
Which year A body and which B or RB motor? I've had big blocks. low and high decks in both style A bodys, 1963 to 1966 and 1967 to 1976 with both chassis and fnederwel headers ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) I like and use fenderwells on race cars ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) Let us know what you got ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) IHTHs
[Re: wayne o]
#1872182
07/17/15 07:23 AM
07/17/15 07:23 AM
RapidRobert
there's the Hooker super comp (equal length) A body BB fenderwell headers that have been around for decades. 5205-1&7/8 and 5215-2". No exp with em but iirc the issue with em is only if you run too large a tire dia, they can rub. www.bigblockdart.com likely might have more info on them if desired
[Re: Exit1965]
#1872264
07/17/15 12:15 PM
07/17/15 12:15 PM
GY3
Wichita
Guys have reported good luck with Hedman underchassis 78030 on BB later A bodies with low deck blocks and manual steering. They are under $200 too!
I have them in my '63 B body and they hug the block and fit really well!
[Re: GY3]
#1872821
07/18/15 11:59 AM
07/18/15 11:59 AM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
Guys have reported good luck with Hedman underchassis 78030 on BB later A bodies with low deck blocks and manual steering. They are under $200 too! ... They don't fit for s_it ![down down](/ubbthreads/images/graemlins/custom/down.gif) I tried, it was a waste of much time and $$. I looked at some of the pictures on the web and Hedman has moved some of the tubes and ruined it for use in an A body. If you are using a manual box Firm Feel has 20:1 and 16:1 gearsets. Steer and Gear has a 16:1 man box, in cast iron. I just put the TTI 1-3/4" full length headers on my car and the fit is so good I kick myself for trying to cheap out with the Hedmans. That being said, there MAY be room for a longer PITMAN arm depending on your setup. I'm using a late spool mount K with the Schumacher mounts. I haven't set my ride height or alignment yet so there may be interference on the Pass side. If you really want quick steering and have some fabrication skills, Speedway has steering quickeners for circle track that you can make work. That's more than I want to get into.
[Re: Exit1965]
#1873376
07/19/15 10:17 AM
07/19/15 10:17 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
Schumachers. EASY to put in. Flow decent, sound good. Friend of mine has those with a 440RB and power steering, car runs mid-11's on drag radials.
"I think its got a hemi"
[Re: Fat_Mike]
#1884339
08/03/15 03:18 PM
08/03/15 03:18 PM
RapidRobert
just thinking out loud: you have a slight bit of leeway on the fore/aft eng/trans location. fab work to relocate the z bar (or revamp the z bar) might be needed. Holler how it turns out
[Re: RapidRobert]
#1885167
08/04/15 08:28 PM
08/04/15 08:28 PM
Posts: 4,320 Prospect, PA
BSB67
Prospect, PA
just thinking out loud: you have a slight bit of leeway on the fore/aft eng/trans location. fab work to relocate the z bar (or revamp the z bar) might be needed. Holler how it turns out I too would look real hard at the Z bar and making it work.
