Headers, Big Block, Abody #1871796
07/16/15 08:03 PM
07/16/15 08:03 PM
pa. usa
W
wayne o Offline OP
wayne o  Offline OP
W
pa. usa
Anyone out there running headers on there Abody w/ a Big Block, that also has the fast ratio steering ? pitman arm, idler arm What headers are you running. TTI says no go, wont fit. I have 69 barracuda 383 4spd.
Re: Headers, Big Block, Abody [Re: wayne o] #1871881
07/16/15 09:39 PM
07/16/15 09:39 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
B or RB?
'63 Dodge 330
11.19 @ 121 mph
Re: Headers, Big Block, Abody [Re: wayne o] #1872138
07/17/15 02:12 AM
07/17/15 02:12 AM
Which year A body and which B or RB motor? I've had big blocks. low and high decks in both style A bodys, 1963 to 1966 and 1967 to 1976 with both chassis and fnederwel headers shruggy I like and use fenderwells on race cars up twocents Let us know what you got up IHTHs
Re: Headers, Big Block, Abody [Re: wayne o] #1872182
07/17/15 07:23 AM
07/17/15 07:23 AM
there's the Hooker super comp (equal length) A body BB fenderwell headers that have been around for decades. 5205-1&7/8 and 5215-2". No exp with em but iirc the issue with em is only if you run too large a tire dia, they can rub. www.bigblockdart.com likely might have more info on them if desired
Re: Headers, Big Block, Abody [Re: wayne o] #1872224
07/17/15 10:59 AM
07/17/15 10:59 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Schumachers. EASY to put in. Flow decent, sound good.
Re: Headers, Big Block, Abody [Re: Exit1965] #1872264
07/17/15 12:15 PM
07/17/15 12:15 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Guys have reported good luck with Hedman underchassis 78030 on BB later A bodies with low deck blocks and manual steering. They are under $200 too!
I have them in my '63 B body and they hug the block and fit really well!
'63 Dodge 330
11.19 @ 121 mph
Re: Headers, Big Block, Abody [Re: GY3] #1872821
07/18/15 11:59 AM
07/18/15 11:59 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Originally Posted By GY3
Guys have reported good luck with Hedman underchassis 78030 on BB later A bodies with low deck blocks and manual steering. They are under $200 too! ...
They don't fit for s_it down I tried, it was a waste of much time and $$. I looked at some of the pictures on the web and Hedman has moved some of the tubes and ruined it for use in an A body. If you are using a manual box Firm Feel has 20:1 and 16:1 gearsets. Steer and Gear has a 16:1 man box, in cast iron. I just put the TTI 1-3/4" full length headers on my car and the fit is so good I kick myself for trying to cheap out with the Hedmans. That being said, there MAY be room for a longer PITMAN arm depending on your setup. I'm using a late spool mount K with the Schumacher mounts. I haven't set my ride height or alignment yet so there may be interference on the Pass side.
If you really want quick steering and have some fabrication skills, Speedway has steering quickeners for circle track that you can make work.
That's more than I want to get into.
Re: Headers, Big Block, Abody [Re: Exit1965] #1873376
07/19/15 10:17 AM
07/19/15 10:17 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Friend of mine has those with a 440RB and power steering, car runs mid-11's on drag radials.
"I think its got a hemi"
Re: Headers, Big Block, Abody [Re: wayne o] #1873707
07/19/15 07:18 PM
07/19/15 07:18 PM
pa. usa
W
wayne o Offline OP
wayne o  Offline OP
W
pa. usa
My car is a 69 383 barracuda 4spd. I was thinking of TTI shorties or Schumacher headers. Any one running them w/ a 4spd abody
Re: Headers, Big Block, Abody [Re: wayne o] #1873935
07/19/15 11:21 PM
07/19/15 11:21 PM
CentralVA.
BBCoronet Offline
BBCoronet  Offline
CentralVA.
Depending on what engine mounts you use the Hedmans will work....I've built 2 in the past year or so...one with DC spool mount style K frame and one with TransDapt conversion mounts(biscuit style) With the TransDapt mounts I used a thicker biscuit mount from a truck to raise the engine 1/2" higher and slid the engine back as far as it would go and got good clearance all around......still had to do some dimpling for the T-bars and mini starter/(stock starter would have cleared) Every car is different but If you have some fabrication skills and don't mind a few small dents for clearance its a cheap way to go....Send me a PM.....I have pix and I can explain how it all goes together....
DADS 72 Dart 013.JPGDADS 72 Dart 009.JPGDADS 72 Dart 052.JPGDADS 72 Dart 053.JPG
Re: Headers, Big Block, Abody [Re: wayne o] #1873952
07/19/15 11:32 PM
07/19/15 11:32 PM
CentralVA.
BBCoronet Offline
BBCoronet  Offline
CentralVA.
You will also have to shorten the steering column's outer sleeve when using the Hedmans but again their a lot cheaper than the $500 & up alternative.
Re: Headers, Big Block, Abody [Re: BBCoronet] #1874186
07/20/15 11:19 AM
07/20/15 11:19 AM
pa. usa
W
wayne o Offline OP
wayne o  Offline OP
W
pa. usa
Thanks. A friend of mine had a BB scamp & he had schumachers. The fit very well, but he had an automatic. I like the idea of the shorties. My only concern is the fitment for the 4spd.
Re: Headers, Big Block, Abody [Re: wayne o] #1884145
08/03/15 10:40 AM
08/03/15 10:40 AM
pa. usa
W
wayne o Offline OP
wayne o  Offline OP
W
pa. usa
OK update- I went with Schumacher tri-y headers. They fit great ! Now my only problem is the left header hits the z bar. I do not want to go with hydraulic. Anyone else have or had the same problem & what did you do to fix it ? THANKS moparts
Re: Headers, Big Block, Abody [Re: wayne o] #1884179
08/03/15 11:29 AM
08/03/15 11:29 AM
N.W. Florida
Fat_Mike Online work
Fat_Mike  Online Work
N.W. Florida
Are those specific headers advertised to fit your application? If so, before you modify anything, call Schumacher and see what they have to say about your situation.
Re: Headers, Big Block, Abody [Re: Fat_Mike] #1884339
08/03/15 03:18 PM
08/03/15 03:18 PM
just thinking out loud: you have a slight bit of leeway on the fore/aft eng/trans location. fab work to relocate the z bar (or revamp the z bar) might be needed. Holler how it turns out
Re: Headers, Big Block, Abody [Re: RapidRobert] #1884565
08/03/15 08:31 PM
08/03/15 08:31 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
4-speed customers: Z-bar interferes with driver side header. You can use a hydraulic clutch system or our headers can be modified to fit a 4-speed transmission. For more modification information go to http://www.accurateltd.com, or email taswope@msn.com
Straight from the website whistling fan rolleyes
Re: Headers, Big Block, Abody [Re: wayne o] #1884608
08/03/15 09:21 PM
08/03/15 09:21 PM
pa. usa
W
wayne o Offline OP
wayne o  Offline OP
W
pa. usa
When using my original A body big block z bar & the clutch fork all I did was grind a spot on the header flange & put a small dent in the header. All is well. No more clearance problems.
Re: Headers, Big Block, Abody [Re: RapidRobert] #1885167
08/04/15 08:28 PM
08/04/15 08:28 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I too would look real hard at the Z bar and making it work.
