Reputable master cylinder rebuilder?
#1865523
07/06/15 11:32 PM
07/06/15 11:32 PM
Posts: 183 La Habra, CA
70440SIXPK
La Habra, CA
Hi guys,
So I'm in a bit of a dilemma. Just got my car finished, full rotisserie.. All the bells and whistles just how us Mopar guys like em, and what do to know .. The guys I had rebuild my master cylinder did it wrong, and leaked brake fluid all over the backside of the cylinder and onto the booster.. So I take it off, go back they allegedly "fix" it.. Repaint, install, bleed SEVERAL times and I have a poor, mushy pedal! No air in the lines.. The car stops, but I wouldn't trust it on the road. It almost feels as if the valve inside is bypassing or something.. Pedal goes all the way to the floor, but will hold talks he car when in drive. Since I have the correct master cylinder on it, I would like it rebuilt correctly and NOT have this issue. Anyone know of a place that can rectify this problem once and for all? I'm done with the place I was dealing with. Sad part about it is this place is a brake a steering "specialist" thanks!
-Nate
1970 Challenger Factory V Code
Re: Reputable master cylinder rebuilder?
[Re: 70440SIXPK]
#1865707
07/07/15 08:48 AM
07/07/15 08:48 AM
Posts: 892 MA
steve70
MA
I had a similar problem and sent mine to http://www.whitepost.com/They did a great job and everything looks and works as it should. Very fast turnaround and a lifetime warranty.
1970 Challenger T/A 4 speed
[Re: floyd]
#1866058
07/07/15 08:30 PM
07/07/15 08:30 PM
Posts: 6,713 KY
65pacecar
KY
I used White Post and Brake & Equipment Warehouse to restore my 171 m/c. I sent it to White Post first, then to Brake & Equipment to get it done right. Similar Story, white post did a booster for me and after a lot of troubleshooting everything else (I assumed the newly rebuilt booster worked) I removed the booster and sent it to Brake Booster Dewey and solved the problem.
[Re: 70-AAR]
#1866182
07/07/15 10:29 PM
07/07/15 10:29 PM
Posts: 8,341 Crook County, ILL
Mastershake340
Crook County, ILL
anyone use ram man? Found him through searching? Heard both good and bad reviews on him. Many Including me have used Brake and Equipment warehouse and been pleased with their work. Good rep, so why take a chance with anyone else?
[Re: 65pacecar]
#1866205
07/07/15 10:53 PM
07/07/15 10:53 PM
70440SIXPK
La Habra, CA
I used White Post and Brake & Equipment Warehouse to restore my 171 m/c. I sent it to White Post first, then to Brake & Equipment to get it done right. Similar Story, white post did a booster for me and after a lot of troubleshooting everything else (I assumed the newly rebuilt booster worked) I removed the booster and sent it to Brake Booster Dewey and solved the problem. Hmmm... do you think that that maybe a booster may be my problem? the pedal goes down at least two inches when the car is not running.... From my experience with late model cars after the first "pump", that thing goes rock solid... given the master is working correctly... If the price is reasonable, I'd consider sending both to get rebuilt, again!... UGH!! that booster is a real PITA to get bolted up!
[Re: 70440SIXPK]
#1867161
07/09/15 12:51 PM
07/09/15 12:51 PM
70440SIXPK
La Habra, CA
Thanks for all the info guys! I really appreciate it!.... Something is definitely wrong with it, I should have known better when the place that I took it to refused to sleeve it (without even seeing it) when I asked to do so.... Now im happy that they didn't sleeve it considering that they can get a couple O-rings right! If they would have ruined my 171 I would have been BEYOND mad!... Hopefully the booster is ok, it seems to be working properly...
[Re: 70-AAR]
#1870293
07/14/15 07:53 PM
07/14/15 07:53 PM
Posts: 3,464 Back in NJ....
EWJ
Back in NJ....
Anyone have a rough idea the price for a MC rebuild at Brake and equipment? Cost $100 with shipping back to me.
Ed EastCoast Land Yacht Assoc. 1967 Newport Conv: 440/4 speed 1969 GTX: 440/4 speed, TX9/TX9, A34, N96 1970 Super Bee: 383/4 speed, B5/B7 1970 Coronet RT: 440/4 speed, A34, N96 1970 Coronet RT: 440/auto, A36, N96 1970 Road Runner convertible: 383/4 speed TX9/D6XW 1970 GTX: 440+6/727, A32, N96 2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed "The early bird may get the worm, but the 2nd mouse gets the cheese".
[Re: reborn73]
#1871056
07/15/15 07:49 PM
07/15/15 07:49 PM
Posts: 16,150 Mesa, Arizona
dart4forte
Mesa, Arizona
I used theramman for the MC and Booster Dewey for the booster. Couldn't be happier with the results I had him do several MCs with good results
Abe Lincoln
[Re: 70440SIXPK]
#1879988
07/28/15 01:20 PM
07/28/15 01:20 PM
70440SIXPK
La Habra, CA
Hi Guys,
Just wanted to give an update .... I ended up going with Karps in Upland (was a little more convenient for me, 15 mins away).... and I must admit, he did a great job! Although the master didnt need to be sleeved, I had him do it anyway. I didnt want to have to deal with pitting/braking problems at a later point in the cars life. One thing i hate dealing with is brake fluid on a fresh restore!
Thanks for all the help guys!!!
-Nathan
[Re: Mastershake340]
#1880922
07/29/15 05:30 PM
07/29/15 05:30 PM
Posts: 531 Charlotte, NC
Kowal
Charlotte, NC
I have used the Ram Man several times. Always great, excellent support on the phone as I ran in to questions.
'69 Hemi Charger 500, ‘70 U code Challenger R/T (These and a bunch others at www.dkowal426.com) P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
