Reputable master cylinder rebuilder? #1865523
07/06/15 11:32 PM
07/06/15 11:32 PM
La Habra, CA
70440SIXPK Offline OP
La Habra, CA
Hi guys,
So I'm in a bit of a dilemma. Just got my car finished, full rotisserie.. All the bells and whistles just how us Mopar guys like em, and what do to know .. The guys I had rebuild my master cylinder did it wrong, and leaked brake fluid all over the backside of the cylinder and onto the booster.. So I take it off, go back they allegedly "fix" it.. Repaint, install, bleed SEVERAL times and I have a poor, mushy pedal! No air in the lines.. The car stops, but I wouldn't trust it on the road. It almost feels as if the valve inside is bypassing or something.. Pedal goes all the way to the floor, but will hold talks he car when in drive. Since I have the correct master cylinder on it, I would like it rebuilt correctly and NOT have this issue. Anyone know of a place that can rectify this problem once and for all? I'm done with the place I was dealing with. Sad part about it is this place is a brake a steering "specialist" thanks!
-Nate
1970 Challenger
Factory V Code
Re: Reputable master cylinder rebuilder? [Re: 70440SIXPK] #1865567
07/07/15 12:16 AM
07/07/15 12:16 AM
Crook County, ILL
Mastershake340 Online content
Mastershake340  Online Content
Crook County, ILL
I've been using and recommending Brake and Equipment Warehouse in MN for many years. Do you have a '9171 disc brake MC? They've done several of those for me.
http://brakeandequipment.com/
Re: Reputable master cylinder rebuilder? [Re: 70440SIXPK] #1865707
07/07/15 08:48 AM
07/07/15 08:48 AM
MA
steve70 Offline
steve70  Offline
MA
I had a similar problem and sent mine to http://www.whitepost.com/
They did a great job and everything looks and works as it should. Very fast turnaround and a lifetime warranty.
1970 Challenger T/A 4 speed
Re: Reputable master cylinder rebuilder? [Re: steve70] #1865725
07/07/15 09:51 AM
07/07/15 09:51 AM
MD
floyd Offline
floyd  Offline
MD
I used White Post and Brake & Equipment Warehouse to restore my 171 m/c. I sent it to White Post first, then to Brake & Equipment to get it done right.
Re: Reputable master cylinder rebuilder? [Re: 70440SIXPK] #1865805
07/07/15 12:14 PM
07/07/15 12:14 PM
California
biggE Offline
biggE  Offline
California
I have been using Power Brake Sales in Sacramento, California for around 30 years without a problem. Here is the number. 800-624-8185 or 916-446-7829.
Re: Reputable master cylinder rebuilder? [Re: floyd] #1866058
07/07/15 08:30 PM
07/07/15 08:30 PM
KY
65pacecar Offline
65pacecar  Offline
KY
Similar Story, white post did a booster for me and after a lot of troubleshooting everything else (I assumed the newly rebuilt booster worked) I removed the booster and sent it to Brake Booster Dewey and solved the problem.
Re: Reputable master cylinder rebuilder? [Re: 70440SIXPK] #1866167
07/07/15 10:15 PM
07/07/15 10:15 PM
CA
70-AAR Offline
70-AAR  Offline
CA
anyone use ram man? Found him through searching?
Re: Reputable master cylinder rebuilder? [Re: 70-AAR] #1866182
07/07/15 10:29 PM
07/07/15 10:29 PM
Crook County, ILL
Crook County, ILL
Heard both good and bad reviews on him.
Many Including me have used Brake and Equipment warehouse and been pleased with their work. Good rep, so why take a chance with anyone else?
Re: Reputable master cylinder rebuilder? [Re: 70440SIXPK] #1866189
07/07/15 10:35 PM
07/07/15 10:35 PM
CA
70-AAR Offline
70-AAR  Offline
CA
Anyone have a rough idea the price for a MC rebuild at Brake and equipment?
Re: Reputable master cylinder rebuilder? [Re: 65pacecar] #1866205
07/07/15 10:53 PM
07/07/15 10:53 PM
La Habra, CA
La Habra, CA
Hmmm... do you think that that maybe a booster may be my problem? the pedal goes down at least two inches when the car is not running.... From my experience with late model cars after the first "pump", that thing goes rock solid... given the master is working correctly... If the price is reasonable, I'd consider sending both to get rebuilt, again!... UGH!! that booster is a real PITA to get bolted up!
1970 Challenger
Factory V Code
Re: Reputable master cylinder rebuilder? [Re: 70440SIXPK] #1866276
07/08/15 12:33 AM
07/08/15 12:33 AM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
I've been using Karp's in Upland California for years no problems. Done several 171 MCs with stainless steal sleeves.
http://www.karpspowerbrake.com/
NS1AAR
Re: Reputable master cylinder rebuilder? [Re: 70440SIXPK] #1866964
07/08/15 11:16 PM
07/08/15 11:16 PM
ar
reborn73 Offline
reborn73  Offline
ar
I used theramman for the MC and Booster Dewey for the booster. Couldn't be happier with the results
Re: Reputable master cylinder rebuilder? [Re: 70440SIXPK] #1867036
07/09/15 01:45 AM
07/09/15 01:45 AM
S.E.Wisconsin
barracudadave67 Offline
S.E.Wisconsin
I rebuilt my own MC, and booster. The brakes are working great again. I got all the parts from "Harmon Classic Brakes" in Valley Glen Ca.
barracudadave67
Re: Reputable master cylinder rebuilder? [Re: 70440SIXPK] #1867161
07/09/15 12:51 PM
07/09/15 12:51 PM
La Habra, CA
La Habra, CA
Thanks for all the info guys! I really appreciate it!.... Something is definitely wrong with it, I should have known better
when the place that I took it to refused to sleeve it (without even seeing it) when I asked to do so.... Now im happy that they didn't sleeve it considering that they can get a couple O-rings right! If they would have ruined my 171 I would have been BEYOND mad!... Hopefully the booster is ok, it seems to be working properly...
1970 Challenger
Factory V Code
Re: Reputable master cylinder rebuilder? [Re: 70440SIXPK] #1868441
07/11/15 09:42 PM
07/11/15 09:42 PM
Spokane Washington
P
pro-streeter Offline
P
Spokane Washington
The ram man did a great job for me
Re: Reputable master cylinder rebuilder? [Re: 70-AAR] #1870293
07/14/15 07:53 PM
07/14/15 07:53 PM
Back in NJ....
E
EWJ Offline
EWJ  Offline
E
Back in NJ....
Cost $100 with shipping back to me.
Ed
EastCoast Land Yacht Assoc.
1967 Newport Conv: 440/4 speed
1969 GTX: 440/4 speed, TX9/TX9, A34, N96
1970 Super Bee: 383/4 speed, B5/B7
1970 Coronet RT: 440/4 speed, A34, N96
1970 Coronet RT: 440/auto, A36, N96
1970 Road Runner convertible: 383/4 speed TX9/D6XW
1970 GTX: 440+6/727, A32, N96
2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed
"The early bird may get the worm, but the 2nd mouse gets the cheese".
Re: Reputable master cylinder rebuilder? [Re: reborn73] #1871056
07/15/15 07:49 PM
07/15/15 07:49 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
iagree
I had him do several MCs with good results
Abe Lincoln
Re: Reputable master cylinder rebuilder? [Re: 70440SIXPK] #1879988
07/28/15 01:20 PM
07/28/15 01:20 PM
La Habra, CA
La Habra, CA
Hi Guys,
Just wanted to give an update .... I ended up going with Karps in Upland (was a little more convenient for me, 15 mins away).... and I must admit, he did a great job! Although the master didnt need to be sleeved, I had him do it anyway. I didnt want to have to deal with pitting/braking problems at a later point in the cars life. One thing i hate dealing with is brake fluid on a fresh restore!
Thanks for all the help guys!!!
-Nathan
1970 Challenger
Factory V Code
Re: Reputable master cylinder rebuilder? [Re: Mastershake340] #1880922
07/29/15 05:30 PM
07/29/15 05:30 PM
Charlotte, NC
Kowal Offline
Kowal  Offline
Charlotte, NC
I have used the Ram Man several times. Always great, excellent support on the phone as I ran in to questions.
'69 Hemi Charger 500, ‘70 U code Challenger R/T
(These and a bunch others at www.dkowal426.com)
P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
