Re: Stall on converter for a 500
[Re: Mopar Guy]
#1854426
06/22/15 04:42 PM
06/22/15 04:42 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Call the guys Dynamic Converter, or Lenny at Ultimate converters and outline your combo and intent, either of these companies should be able to get you into the right converter. There's a few others that will be suggested here as well. I run a Dynamic 9-1/2" converter that was custom built for my combo, and it has performed great for a few years now. I'd use these guys again, but most here tend to speak real high Lenny.
[Re: Mopar Guy]
#1854637
06/22/15 07:50 PM
06/22/15 07:50 PM
Posts: 2,467 Sydney,Australia
tex013
Sydney,Australia
I am with Stealth I ran a 509 cam in a 440 daily driver strip car , they love comp - stall - gear I had a 4200 originally with 3.9 gears , got a Dynamic 9 1/2 (5100) then 4.10 gears . Kept going faster . Even with the stroker I would not look under 4000 and a bit more gear . my 2 cents
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: Mopar Guy]
#1854721
06/22/15 09:30 PM
06/22/15 09:30 PM
Posts: 3,210 robin hood country
deaks
robin hood country
With your combo and intended usage, you would have been better posting this in question and answer because a lot of people that frequent this part of the site are in the "too much is just right" category. If it is mostly street use and possible long runs i wouldn't go over 3000 stall and use the 3.23 gears, the extra cubes will swallow a lot of the .509's dur up. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: Mopar Guy]
#1854731
06/22/15 09:40 PM
06/22/15 09:40 PM
Posts: 12,158 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
PTC (Performance Torque Converter) They are Mopar guys that get it right the first time and are affordable.
Master, again and still
[Re: DaveRS23]
#1854741
06/22/15 09:49 PM
06/22/15 09:49 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
PTC (Performance Torque Converter) They are Mopar guys that get it right the first time and are affordable. I agree with Dave....
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: Mopar Guy]
#1854812
06/22/15 11:25 PM
06/22/15 11:25 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
You will definitely have to stress your preference's to the converter builder for this car. Stress what rpm you are willing to allow for cruise speed. He should be able to build you a unit that you are happy with, and not have to send it back to change the stall.
[Re: Mopar Guy]
#1854849
06/23/15 12:01 AM
06/23/15 12:01 AM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
Put your motor on a dyno, go to your favorite convertor guy, give him the dyno sheet, AND the info on your car, weight, gear, tire. Dave
[Re: quickd100]
#1854856
06/23/15 12:09 AM
06/23/15 12:09 AM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
Had a off the shelf 10" ATI behind the 493" for years. Run 3.55s and a 30" tall tire. Great street manners, would drive like normal just about until you punched it, and would flash to ~4000+ rpm
Switched to a 9 1/2 Dynamic spec'd for it, and it picked up a little at the track, but the street manners suffered a bit.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
