Stall on converter for a 500 #1854384
06/22/15 03:52 PM
06/22/15 03:52 PM
Sweden
Mopar Guy Offline OP
Sweden
Im trying to figure out what a good stall and zice on the converter would be on a rb 500 whit a 509 hydralic cam would be in a 68 Charger 3:23 or 3:55 rear end for the street mostly.
Re: Stall on converter for a 500 [Re: Mopar Guy] #1854426
06/22/15 04:42 PM
06/22/15 04:42 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Call the guys Dynamic Converter, or Lenny at Ultimate converters and outline your combo and intent, either of these companies should be able to get you into the right converter. There's a few others that will be suggested here as well. I run a Dynamic 9-1/2" converter that was custom built for my combo, and it has performed great for a few years now. I'd use these guys again, but most here tend to speak real high Lenny.
Re: Stall on converter for a 500 [Re: Mopar Guy] #1854456
06/22/15 05:12 PM
06/22/15 05:12 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
As I always do... I suggest a call to Turbo Action.
www.turboaction.com
Nautilus Racing-
Re: Stall on converter for a 500 [Re: Mopar Guy] #1854637
06/22/15 07:50 PM
06/22/15 07:50 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
I am with Stealth
I ran a 509 cam in a 440 daily driver strip car , they love comp - stall - gear
I had a 4200 originally with 3.9 gears , got a Dynamic 9 1/2 (5100) then 4.10 gears . Kept going faster .
Even with the stroker I would not look under 4000 and a bit more gear .
my 2 cents
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Stall on converter for a 500 [Re: Mopar Guy] #1854721
06/22/15 09:30 PM
06/22/15 09:30 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
With your combo and intended usage, you would have been better posting this in question and answer because a lot of people that frequent this part of the site are in the "too much is just right" category. If it is mostly street use and possible long runs i wouldn't go over 3000 stall and use the 3.23 gears, the extra cubes will swallow a lot of the .509's dur up.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Stall on converter for a 500 [Re: Mopar Guy] #1854731
06/22/15 09:40 PM
06/22/15 09:40 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
PTC (Performance Torque Converter) They are Mopar guys that get it right the first time and are affordable.
Master, again and still
Re: Stall on converter for a 500 [Re: DaveRS23] #1854741
06/22/15 09:49 PM
06/22/15 09:49 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I agree with Dave....
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Stall on converter for a 500 [Re: D-50] #1854796
06/22/15 11:04 PM
06/22/15 11:04 PM
MI, Lapeer
maximus Offline
maximus  Offline
MI, Lapeer
I buy mine from PTC. They build what you need and they work great.
Re: Stall on converter for a 500 [Re: Mopar Guy] #1854812
06/22/15 11:25 PM
06/22/15 11:25 PM
gregsdart Offline
gregsdart  Offline
You will definitely have to stress your preference's to the converter builder for this car. Stress what rpm you are willing to allow for cruise speed. He should be able to build you a unit that you are happy with, and not have to send it back to change the stall.
Re: Stall on converter for a 500 [Re: Mopar Guy] #1854849
06/23/15 12:01 AM
06/23/15 12:01 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Put your motor on a dyno, go to your favorite convertor guy, give him the dyno sheet, AND the info on your car, weight, gear, tire. Dave
Re: Stall on converter for a 500 [Re: quickd100] #1854856
06/23/15 12:09 AM
06/23/15 12:09 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Had a off the shelf 10" ATI behind the 493" for years. Run 3.55s and a 30" tall tire. Great street manners, would drive like normal just about until you punched it, and would flash to ~4000+ rpm
Switched to a 9 1/2 Dynamic spec'd for it, and it picked up a little at the track, but the street manners suffered a bit.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Stall on converter for a 500 [Re: Mopar Guy] #1854929
06/23/15 01:41 AM
06/23/15 01:41 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I'm running an off the shelf TA 2800 converter from Mancini in my 9:1 493 with that same cam and 3.23's.
It's in a 4800 lb C body. My engine is making 500 ft/lbs by 2000 so it worked OK on the street but the 1100 RPM idle was banging the crap out of the drive line when you put it in gear.
Kevin
