Re: leaf spring relocation kit
[Re: dartphil]
#1850683
06/16/15 08:22 PM
06/16/15 08:22 PM
Posts: 878 lancaster,california
johnnycuda
The only difference I can of would be the diameter of the rear shackle bushings, .500 for A-bodies and .562 for B/E bodies.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
[Re: johnnycuda]
#1850691
06/16/15 08:34 PM
06/16/15 08:34 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
There is nothing to it. I bought one for my Demon and after I got it I thought I wasted my money. On my 69 Valiant I just cut the frame notch and made my own box to weld in. I might have had $10 in it.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: dartphil]
#1850714
06/16/15 09:13 PM
06/16/15 09:13 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
I am doing this right now on my Demon. I built my own boxes for long springs, bought Calverts spring perches(nice), and Afco sliders.
The factory spring mounts are not the most accurate layout and were designed for rubber bushings that could handle some misalignment. Do you want to use the factory mounts to locate your new stuff like the US Cartool stuff? If so that could be easier, just do yourself a favor and slip a rod through the spring holes from side to side to help line them up before you weld.
"Just a Bracket car dressed up like a streetcar"
[Re: Just-a-dart]
#1850725
06/16/15 09:24 PM
06/16/15 09:24 PM
D-50
North, Alabama
If you can weld the frame box in I do not see why you can't just build the box also and save the money. Just buy the spring mounts.
[Re: D-50]
#1851082
06/17/15 01:44 PM
06/17/15 01:44 PM
Thumperdart
State of confusion
If you can weld the frame box in I do not see why you can't just build the box also and save the money. Just buy the spring mounts. Agreed.......................my friend built the baddest and thickest boxes I`ve ever seen and welded em in for me which tie right into my subframe connectors.
[Re: dartphil]
#1851086
06/17/15 01:49 PM
06/17/15 01:49 PM
Posts: 625 Indianapolis In. usa
Quickrunner
Made these from scratch, way less than the flimsy mopar kit. Going with sliders in back. Front of the box is welded right to frame connector as well as a tube crossmember.
05 Ram 1500 Daytona package 71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
[Re: johnnycuda]
#1851571
06/18/15 01:06 AM
06/18/15 01:06 AM
Posts: 12,595 Great Neck,LI,new york
hemi-itis
The only difference I can of would be the diameter of the rear shackle bushings, .500 for A-bodies and .562 for B/E bodies. Caltrak uses a 1 inch spring eye In the rear spring!!
[Re: Just-a-dart]
#1851578
06/18/15 01:15 AM
06/18/15 01:15 AM
hemi-itis
The factory spring mounts are not the most accurate layout and were designed for rubber bushings that could handle some misalignment. Do you want to use the factory mounts to locate your new stuff like the US Cartool stuff? If so that could be easier, just do yourself a favor and slip a rod through the spring holes from side to side to help line them up before you weld. Save yourself some hassle,return the Affco and get the Caltrac sliders.They come with the right size bushings,,,,,,,,,,,,
[Re: hemi-itis]
#1851607
06/18/15 02:32 AM
06/18/15 02:32 AM
Just-a-dart
Glendora Ca.
Save yourself some hassle,return the Affco and get the Caltrac sliders.They come with the right size bushings,,,,,,,,,,,, [/quote]
I just saw that Calvert was making a slider, earlier today looks nice. He set me up with the right bushings for the Afco sliders when I bought the springs a while back. Thanks for the heads up anyway Hemi-itis
