leaf spring relocation kit #1850639
06/16/15 07:51 PM
06/16/15 07:51 PM
st. Louis Mo.
dartphil Offline OP
dartphil  Offline OP
st. Louis Mo.
I was just looking at the mopar spring relocation kits,and noticed the a-body kit is almost double the price of the b-body kit. What is the difference? Could I use the b-body kit on my a-body?
Re: leaf spring relocation kit [Re: dartphil] #1850683
06/16/15 09:22 PM
06/16/15 09:22 PM
lancaster,california
johnnycuda Offline
johnnycuda  Offline
The only difference I can of would be the diameter of the rear shackle bushings, .500 for A-bodies and .562 for B/E bodies.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT!
1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air,
New daily driver-2003 Ram 2500 Cummins 5.9
'69 Valiant 2-dr, sleeper!
New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: leaf spring relocation kit [Re: johnnycuda] #1850691
06/16/15 09:34 PM
06/16/15 09:34 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
There is nothing to it. I bought one for my Demon and after I got it I thought I wasted my money. On my 69 Valiant I just cut the frame notch and made my own box to weld in. I might have had $10 in it.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: leaf spring relocation kit [Re: D-50] #1850694
06/16/15 09:39 PM
06/16/15 09:39 PM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
Not sure what justifies the price difference or what components differ.
In any event, This was the article I read before I welded in the MP kit on my car:
http://www.bigblockdart.com/techpages/springs.shtml
You might also take a look at the U.S. Car Tool Kit, same $199, but looks to be a better setup:
http://store.uscartool.com/mopar-a-body-spring-hanger-relocation-kit.html
Re: leaf spring relocation kit [Re: dartphil] #1850714
06/16/15 10:13 PM
06/16/15 10:13 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
I am doing this right now on my Demon. I built my own boxes for long springs, bought Calverts spring perches(nice), and Afco sliders.
The factory spring mounts are not the most accurate layout and were designed for rubber bushings that could handle some misalignment. Do you want to use the factory mounts to locate your new stuff like the US Cartool stuff? If so that could be easier, just do yourself a favor and slip a rod through the spring holes from side to side to help line them up before you weld.
"Just a Bracket car dressed up like a streetcar"
Re: leaf spring relocation kit [Re: Just-a-dart] #1850725
06/16/15 10:24 PM
06/16/15 10:24 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
If you can weld the frame box in I do not see why you can't just build the box also and save the money. Just buy the spring mounts.
Re: leaf spring relocation kit [Re: dartphil] #1850731
06/16/15 10:28 PM
06/16/15 10:28 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
A body is the new E body stirthepot
Re: leaf spring relocation kit [Re: D-50] #1851082
06/17/15 02:44 PM
06/17/15 02:44 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Agreed.......................my friend built the baddest and thickest boxes I`ve ever seen and welded em in for me which tie right into my subframe connectors.
Re: leaf spring relocation kit [Re: dartphil] #1851086
06/17/15 02:49 PM
06/17/15 02:49 PM
Indianapolis In. usa
Quickrunner Offline
Quickrunner  Offline
Made these from scratch, way less than the flimsy mopar kit. Going with sliders in back. Front of the box is welded right to frame connector as well as a tube crossmember.
05 Ram 1500 Daytona package
71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
Re: leaf spring relocation kit [Re: dartphil] #1851088
06/17/15 02:51 PM
06/17/15 02:51 PM
Quickrunner Offline
Quickrunner  Offline
4x6 3/16 wall
Re: leaf spring relocation kit [Re: johnnycuda] #1851571
06/18/15 02:06 AM
06/18/15 02:06 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Caltrak uses a 1 inch spring eye In the rear spring!!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: leaf spring relocation kit [Re: Just-a-dart] #1851578
06/18/15 02:15 AM
06/18/15 02:15 AM
hemi-itis Offline
hemi-itis  Offline
Save yourself some hassle,return the Affco and get the Caltrac sliders.They come with the right size bushings,,,,,,,,,,,,
Re: leaf spring relocation kit [Re: hemi-itis] #1851607
06/18/15 03:32 AM
06/18/15 03:32 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Save yourself some hassle,return the Affco and get the Caltrac sliders.They come with the right size bushings,,,,,,,,,,,, [/quote]
I just saw that Calvert was making a slider, earlier today looks nice. He set me up with the right bushings for the Afco sliders when I bought the springs a while back. Thanks for the heads up anyway Hemi-itis
