NE1 running mid to low 11's with a 3.55 gear SB? #1833412
05/24/15 08:07 PM
05/24/15 08:07 PM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
Stroked or stock stroke, let me hear the details! starting to decide which way to go on my build.
Re: NE1 running mid to low 11's with a 3.55 gear SB? [Re: ademon] #1833420
05/24/15 08:14 PM
05/24/15 08:14 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Get enough converter and the gears won't mess with you much. Ive been 11.18@120.5 with a stock stroke 340 and a 3.91 gear @3525 lbs so I won't be much help.
68 Barracuda Formula S 340
Re: NE1 running mid to low 11's with a 3.55 gear SB? [Re: Bad340fish] #1833462
05/24/15 09:42 PM
05/24/15 09:42 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Mine is a 340 stroked to 394. I broke the gears I had and stuck some 3.50's in so I could race. I ran a 6.39 @ 109 in the 1/8 crossing the finish line in 2nd gear. That converts to a 10.09 1/4. Also running a 30 in. tall tire.2950lbs
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: NE1 running mid to low 11's with a 3.55 gear SB? [Re: D-50] #1833470
05/24/15 09:49 PM
05/24/15 09:49 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Interesting question. I'm sure the converter spec is critical.
I'm kinda hoping for something similar, if I do a 4" crank 360. High 11's in 100% street trim with a 3.23 gear and 27" tall drag radial.
Re: NE1 running mid to low 11's with a 3.55 gear SB? [Re: ademon] #1833471
05/24/15 09:52 PM
05/24/15 09:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you get the car light enough you can run a 2.90 gear OR
hang a turbo on it
wave
Re: NE1 running mid to low 11's with a 3.55 gear SB? [Re: cudadoug] #1833478
05/24/15 10:07 PM
05/24/15 10:07 PM
CA
crackedback Online content
crackedback  Online Content
CA
With 450 pounds of TQ at 3K and up, yeah shouldn't be an issue.
Re: NE1 running mid to low 11's with a 3.55 gear SB? [Re: ademon] #1833482
05/24/15 10:11 PM
05/24/15 10:11 PM
Dayton, OH
1980volare Offline
My man card has just been revoked.
1980volare  Offline
Dayton, OH
10.0 @ 137(so far) with a 3.23 gear @3500lbs. You need a turbo, you won't regret it.
Re: NE1 running mid to low 11's with a 3.55 gear SB? [Re: cudadoug] #1833506
05/24/15 10:48 PM
05/24/15 10:48 PM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
stock appearing street trim 71 demon with 26 or 28" drag radials, weight would be about 3,450 with me in it. I have a 4,400 stall already with the 360, I'm hoping a 426" stroker with a worked 6 pack manifold and my TTI's will get me 11.30 or 40's in summer driving it in the gate and just lowering rear tire psi!
Re: NE1 running mid to low 11's with a 3.55 gear SB? [Re: ademon] #1833541
05/24/15 11:32 PM
05/24/15 11:32 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
9.88 @ 134 with a NA sb gen 3. 3.55 gear.3150 lbs
Re: NE1 running mid to low 11's with a 3.55 gear SB? [Re: ademon] #1833590
05/25/15 12:22 AM
05/25/15 12:22 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
If you don't end up going with a turbo, build as many cubes as you can, at least a 408. My current street car is a mild 500" big block, I installed 3.55 gears so I could drive it alot and I thought it would be a dog with those gears, it is not!! It feels so good with 275/60/15 tires that I'm considering 3.23 gears for next year. Right now I'm at 2800 RPM's at 60 mph.
If you're only shooting for 11's, just build a nice combo with cubes, good heads, and the right converter. I used to run 9's with 4.30 and 4.56 gears, now I just want to run 10's or 11's and be able to drive it alot.
Re: NE1 running mid to low 11's with a 3.55 gear SB? [Re: ProSport] #1833598
05/25/15 12:34 AM
05/25/15 12:34 AM
MR_P_BODY Offline
MR_P_BODY  Offline
One other thing that people never seem to use or think of
is a OD trans.. I set my DW car to run the 518 trans(because
they are cheaper) or you can use a GV OD... I use a set of 4.10
gears and a set of 295/55/15 tires... a 5000 stall because I had
it.. but this set up should run 10.0 and cruise at 75 mph at 2900 rpm
wave
Re: NE1 running mid to low 11's with a 3.55 gear SB? [Re: ademon] #1833600
05/25/15 12:36 AM
05/25/15 12:36 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
No doubt, I am definitely saving my pennies for a GV overdrive, just haven't been able to afford one yet.
Re: NE1 running mid to low 11's with a 3.55 gear SB? [Re: ProSport] #1833605
05/25/15 12:43 AM
05/25/15 12:43 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Bob.. I just bought another 518 for my set up right before I
went into the hospital... it was $300... and I might use it as is..
this one is the early 2 pin 518 that DIDNT have lock up so its the
727 conv.... sure beats paying $3000 for the GV
wave
Re: NE1 running mid to low 11's with a 3.55 gear SB? [Re: ademon] #1833613
05/25/15 12:59 AM
05/25/15 12:59 AM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
Does a 518 bolt up without any tunnel mods?
Re: NE1 running mid to low 11's with a 3.55 gear SB? [Re: ademon] #1833661
05/25/15 02:17 AM
05/25/15 02:17 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont think so.. but I dont start with stock stuff either... but to
build up a tunnel is pretty easy
wave
Re: NE1 running mid to low 11's with a 3.55 gear SB? [Re: ademon] #1833982
05/25/15 04:30 PM
05/25/15 04:30 PM
Which body year and style? Weight and frontal area matter work shruggy 11.55 E.T. in the 1/4 mile in any Mopar body with a semi stock SB is very fast on pump gas N/A motor bow twocents
Re: NE1 running mid to low 11's with a 3.55 gear SB? [Re: ademon] #1833995
05/25/15 04:49 PM
05/25/15 04:49 PM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
71 demon about 3450lbs with me in it. Looks doable with 3.55. Maybe would go up to 3.73 since the expressway trips are usually under 40min.
Re: NE1 running mid to low 11's with a 3.55 gear SB? [Re: ademon] #1834047
05/25/15 06:40 PM
05/25/15 06:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Being realistic here... what is the car used for..
you could put the 3.55 and the low trans first gear
wave
Re: NE1 running mid to low 11's with a 3.55 gear SB? [Re: ademon] #1834118
05/25/15 08:19 PM
05/25/15 08:19 PM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
Mostly weekend cruising, few trips a year to the drag strip. The more I think it over the more I want a less radical engine cam and compression wise, hence the 426" or bigger SB.
