Re: NE1 running mid to low 11's with a 3.55 gear SB?
[Re: ademon]
#1833420
05/24/15 08:14 PM
05/24/15 08:14 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
Get enough converter and the gears won't mess with you much. Ive been 11.18@120.5 with a stock stroke 340 and a 3.91 gear @3525 lbs so I won't be much help.
68 Barracuda Formula S 340
[Re: Bad340fish]
#1833462
05/24/15 09:42 PM
05/24/15 09:42 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
Mine is a 340 stroked to 394. I broke the gears I had and stuck some 3.50's in so I could race. I ran a 6.39 @ 109 in the 1/8 crossing the finish line in 2nd gear. That converts to a 10.09 1/4. Also running a 30 in. tall tire.2950lbs
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: ademon]
#1833471
05/24/15 09:52 PM
05/24/15 09:52 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Stroked or stock stroke, let me hear the details! starting to decide which way to go on my build. If you get the car light enough you can run a 2.90 gear OR hang a turbo on it
[Re: cudadoug]
#1833478
05/24/15 10:07 PM
05/24/15 10:07 PM
Posts: 2,078 CA
crackedback
CA
Interesting question. I'm sure the converter spec is critical.
I'm kinda hoping for something similar, if I do a 4" crank 360. High 11's in 100% street trim with a 3.23 gear and 27" tall drag radial.
With 450 pounds of TQ at 3K and up, yeah shouldn't be an issue.
[Re: ademon]
#1833482
05/24/15 10:11 PM
05/24/15 10:11 PM
Posts: 582 Dayton, OH
1980volare
My man card has just been revoked.
Dayton, OH
10.0 @ 137(so far) with a 3.23 gear @3500lbs. You need a turbo, you won't regret it.
[Re: cudadoug]
#1833506
05/24/15 10:48 PM
05/24/15 10:48 PM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
stock appearing street trim 71 demon with 26 or 28" drag radials, weight would be about 3,450 with me in it. I have a 4,400 stall already with the 360, I'm hoping a 426" stroker with a worked 6 pack manifold and my TTI's will get me 11.30 or 40's in summer driving it in the gate and just lowering rear tire psi!
[Re: ademon]
#1833541
05/24/15 11:32 PM
05/24/15 11:32 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
9.88 @ 134 with a NA sb gen 3. 3.55 gear.3150 lbs
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: ademon]
#1833590
05/25/15 12:22 AM
05/25/15 12:22 AM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
If you don't end up going with a turbo, build as many cubes as you can, at least a 408. My current street car is a mild 500" big block, I installed 3.55 gears so I could drive it alot and I thought it would be a dog with those gears, it is not!! It feels so good with 275/60/15 tires that I'm considering 3.23 gears for next year. Right now I'm at 2800 RPM's at 60 mph.
If you're only shooting for 11's, just build a nice combo with cubes, good heads, and the right converter. I used to run 9's with 4.30 and 4.56 gears, now I just want to run 10's or 11's and be able to drive it alot.
[Re: ProSport]
#1833598
05/25/15 12:34 AM
05/25/15 12:34 AM
MR_P_BODY
One other thing that people never seem to use or think of is a OD trans.. I set my DW car to run the 518 trans(because they are cheaper) or you can use a GV OD... I use a set of 4.10 gears and a set of 295/55/15 tires... a 5000 stall because I had it.. but this set up should run 10.0 and cruise at 75 mph at 2900 rpm
[Re: ademon]
#1833600
05/25/15 12:36 AM
05/25/15 12:36 AM
ProSport
Akron, Ohio
No doubt, I am definitely saving my pennies for a GV overdrive, just haven't been able to afford one yet.
[Re: ProSport]
#1833605
05/25/15 12:43 AM
05/25/15 12:43 AM
MR_P_BODY
No doubt, I am definitely saving my pennies for a GV overdrive, just haven't been able to afford one yet. Bob.. I just bought another 518 for my set up right before I went into the hospital... it was $300... and I might use it as is.. this one is the early 2 pin 518 that DIDNT have lock up so its the 727 conv.... sure beats paying $3000 for the GV
[Re: ademon]
#1833661
05/25/15 02:17 AM
05/25/15 02:17 AM
MR_P_BODY
Does a 518 bolt up without any tunnel mods? I dont think so.. but I dont start with stock stuff either... but to build up a tunnel is pretty easy
[Re: ademon]
#1834047
05/25/15 06:40 PM
05/25/15 06:40 PM
MR_P_BODY
71 demon about 3450lbs with me in it. Looks doable with 3.55. Maybe would go up to 3.73 since the expressway trips are usually under 40min. Being realistic here... what is the car used for.. you could put the 3.55 and the low trans first gear
