The pinion angle thread: A helpful hint #1825194
05/12/15 08:28 PM
05/12/15 08:28 PM
Baltimore/Denver
64Post Offline OP
64Post  Offline OP
Baltimore/Denver
Looking through the pinion angle thread gave me a headache, so I'd like to provide a helpful hint for most of you fine folks. If you hold down the alt/option key and hit the "0" key on your keyboard, you can use the degree character. (At least I can; if you can't then too bad)
See: 4º, there it is...
4º, there it is again... no magic involved.
One more time ...4º
So stop using * instead of º, you look like idiots. laugh2
You're Welcome! biggrin tonguue
Warning: Above post may contain good-natured ribbing, sarcasm and general smart-assery. Don't get your knickers in a knot. It's all in good fun.
Re: The pinion angle thread: A helpful hint [Re: 64Post] #1825267
05/12/15 10:42 PM
05/12/15 10:42 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Another way to get the degree symbol, is to hold down the ALT key, and type 167.
thumbs
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: The pinion angle thread: A helpful hint [Re: 64Post] #1825286
05/12/15 11:12 PM
05/12/15 11:12 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Watch out Post...that's a rough crowd on that thread... whistling It's good no one knows where you really are... catfight rant argue
...FAFO...
Re: The pinion angle thread: A helpful hint [Re: 64Post] #1825361
05/13/15 12:25 AM
05/13/15 12:25 AM
CA
crackedback Offline
crackedback  Offline
CA
F*********************** Y**************************
Re: The pinion angle thread: A helpful hint [Re: 64Post] #1825363
05/13/15 12:27 AM
05/13/15 12:27 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
One more time ...4º
4, Not here brother! Here Alt/option and 0 key = 4, as just shown.
For me, its 4 + alt 0176 on the right hand numbers pad. 4°
To much Extra work for me, when I can just do, 4*
And , most will/should understand that.
For me 1 Extra poke, VS 5 Extra pokes on the key board.
Not a idiot here, just lazy.
Appreciate your concern and Humor. But, Your Pinion angle ** help stuff isn't helping me. °°°° LOL
But. I will review the other ways that people have been successful at. * vs °
Re: The pinion angle thread: A helpful hint [Re: Sport440] #1825370
05/13/15 12:39 AM
05/13/15 12:39 AM
MR_P_BODY Offline
MR_P_BODY  Offline
One more time ...4º
And , the Elite should understand that.
Same here... its not worth my time.. everyone seems to know
what this means *... so I'll continue to use it
wave
Re: The pinion angle thread: A helpful hint [Re: Sport440] #1825385
05/13/15 12:50 AM
05/13/15 12:50 AM
Baltimore/Denver
64Post Offline OP
64Post  Offline OP
Baltimore/Denver
One more time ...4º
5, Not here brother! Here Alt/option and 0 key = 5, as just shown.
For me, its 5 + alt 0176 on the right hand numbers pad. 5°
To much Extra work for me, when I can just do, 5*
Perhaps a keyboard shortcut is in order. wave
P.S. My apologies for inadvertently referring to you as an idiot. I'll add you to the lazy column instead. laugh2
Re: The pinion angle thread: A helpful hint [Re: crackedback] #1825388
05/13/15 12:52 AM
05/13/15 12:52 AM
Baltimore/Denver
64Post Offline OP
64Post  Offline OP
Baltimore/Denver
Your º of humor is appreciated. haha
Re: The pinion angle thread: A helpful hint [Re: skicker] #1825392
05/13/15 12:54 AM
05/13/15 12:54 AM
Baltimore/Denver
64Post Offline OP
64Post  Offline OP
Baltimore/Denver
I rolled past your place (generally) Sunday morning on the way out of town. My work is done until the next riot.
Re: The pinion angle thread: A helpful hint [Re: 64Post] #1825514
05/13/15 10:01 AM
05/13/15 10:01 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
laugh2
...FAFO...
Re: The pinion angle thread: A helpful hint [Re: 64Post] #1825651
05/13/15 12:42 PM
05/13/15 12:42 PM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
You get what you get... -4* + You Deflection... smile
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: The pinion angle thread: A helpful hint [Re: 64Post] #1825849
05/13/15 04:24 PM
05/13/15 04:24 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Doesn't work for me. Someone else told me the "degree" key was beside the "any" key but I haven't been able to find it.
Re: The pinion angle thread: A helpful hint [Re: CMcAllister] #1826034
05/13/15 08:32 PM
05/13/15 08:32 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Try This; Push/hold the Alt key, then type 0176 on the Far right numeral pad, then release. And Wallya °
Re: The pinion angle thread: A helpful hint [Re: 64Post] #1826312
05/14/15 12:20 AM
05/14/15 12:20 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
One more time ...4º
Settle down, "Richard"! laugh2
'63 Dodge 330
11.19 @ 121 mph
Re: The pinion angle thread: A helpful hint [Re: 64Post] #1826325
05/14/15 12:28 AM
05/14/15 12:28 AM
Kirkland, Washington
Pacnorthcuda Offline
I am 2* from Kevin Bacon (my wife is 1).
Re: The pinion angle thread: A helpful hint [Re: Sport440] #1826350
05/14/15 12:48 AM
05/14/15 12:48 AM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Adding the 0 to the 176 gives me a funky symbol. ALT and 167 on the keypad works for me.
