The pinion angle thread: A helpful hint
#1825194
05/12/15 08:28 PM
05/12/15 08:28 PM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
Looking through the pinion angle thread gave me a headache, so I'd like to provide a helpful hint for most of you fine folks. If you hold down the alt/option key and hit the "0" key on your keyboard, you can use the degree character. (At least I can; if you can't then too bad) See: 4 º, there it is... 4 º, there it is again... no magic involved. One more time ...4 º So stop using * instead of º, you look like idiots. You're Welcome! Warning: Above post may contain good-natured ribbing, sarcasm and general smart-assery. Don't get your knickers in a knot. It's all in good fun.
Re: The pinion angle thread: A helpful hint
[Re: 64Post]
#1825267
05/12/15 10:42 PM
05/12/15 10:42 PM
Posts: 1,845 Tampa
DusterDave
Tampa
Another way to get the degree symbol, is to hold down the ALT key, and type 167. 4º
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: 64Post]
#1825363
05/13/15 12:27 AM
05/13/15 12:27 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Looking through the pinion angle thread gave me a headache, so I'd like to provide a helpful hint for most of you fine folks. If you hold down the alt/option key and hit the "0" key on your keyboard, you can use the degree character. (At least I can; if you can't then too bad) See: 4 º, there it is... 4 º, there it is again... no magic involved. One more time ...4 º So stop using * instead of º, you look like idiots. You're Welcome! Warning: Above post may contain good-natured ribbing, sarcasm and general smart-assery. Don't get your knickers in a knot. It's all in good fun. 4, Not here brother! Here Alt/option and 0 key = 4, as just shown. For me, its 4 + alt 0176 on the right hand numbers pad. 4° To much Extra work for me, when I can just do, 4* And , most will/should understand that. For me 1 Extra poke, VS 5 Extra pokes on the key board. Not a idiot here, just lazy. Appreciate your concern and Humor. But, Your Pinion angle ** help stuff isn't helping me. °°°° LOL But. I will review the other ways that people have been successful at. * vs °
[Re: Sport440]
#1825370
05/13/15 12:39 AM
05/13/15 12:39 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Looking through the pinion angle thread gave me a headache, so I'd like to provide a helpful hint for most of you fine folks. If you hold down the alt/option key and hit the "0" key on your keyboard, you can use the degree character. (At least I can; if you can't then too bad) See: 4 º, there it is... 4 º, there it is again... no magic involved. One more time ...4 º So stop using * instead of º, you look like idiots. You're Welcome! Warning: Above post may contain good-natured ribbing, sarcasm and general smart-assery. Don't get your knickers in a knot. It's all in good fun. 4, Not here brother! Here Alt/option and 0 key = 4, as just shown. For me, its 4 + alt 0176 on the right hand numbers pad. 4° To much Extra work for me, when I can just do, 4* And , the Elite should understand that. For me 1 Extra poke, VS 5 Extra pokes on the key board. Not a idiot here, just lazy. Appreciate your concern and Humor. But, Your Pinion angle ** help stuff isn't helping me. °°°° LOL But. I will review the other ways that people have been successful at. * vs ° Same here... its not worth my time.. everyone seems to know what this means *... so I'll continue to use it
[Re: Sport440]
#1825385
05/13/15 12:50 AM
05/13/15 12:50 AM
64Post
Baltimore/Denver
Looking through the pinion angle thread gave me a headache, so I'd like to provide a helpful hint for most of you fine folks. If you hold down the alt/option key and hit the "0" key on your keyboard, you can use the degree character. (At least I can; if you can't then too bad) See: 4 º, there it is... 4 º, there it is again... no magic involved. One more time ...4 º So stop using * instead of º, you look like idiots. You're Welcome! Warning: Above post may contain good-natured ribbing, sarcasm and general smart-assery. Don't get your knickers in a knot. It's all in good fun. 5, Not here brother! Here Alt/option and 0 key = 5, as just shown. For me, its 5 + alt 0176 on the right hand numbers pad. 5° To much Extra work for me, when I can just do, 5* And , the Elite should understand that. For me 1 Extra poke, VS 5 Extra pokes on the key board. Not a idiot here, just lazy. Perhaps a keyboard shortcut is in order. P.S. My apologies for inadvertently referring to you as an idiot. I'll add you to the lazy column instead.
[Re: 64Post]
#1825849
05/13/15 04:24 PM
05/13/15 04:24 PM
Posts: 11,602 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Doesn't work for me. Someone else told me the "degree" key was beside the "any" key but I haven't been able to find it.
[Re: CMcAllister]
#1826034
05/13/15 08:32 PM
05/13/15 08:32 PM
Sport440
Canton, Ohio
Doesn't work for me. Someone else told me the "degree" key was beside the "any" key but I haven't been able to find it. Try This; Push/hold the Alt key, then type 0176 on the Far right numeral pad, then release. And Wallya ° ° :-}
[Re: 64Post]
#1826312
05/14/15 12:20 AM
05/14/15 12:20 AM
Posts: 4,684 Wichita
GY3
Wichita
Looking through the pinion angle thread gave me a headache, so I'd like to provide a helpful hint for most of you fine folks. If you hold down the alt/option key and hit the "0" key on your keyboard, you can use the degree character. (At least I can; if you can't then too bad) See: 4 º, there it is... 4 º, there it is again... no magic involved. One more time ...4 º So stop using * instead of º, you look like idiots. You're Welcome! Warning: Above post may contain good-natured ribbing, sarcasm and general smart-assery. Don't get your knickers in a knot. It's all in good fun. 5, Not here brother! Here Alt/option and 0 key = 5, as just shown. For me, its 5 + alt 0176 on the right hand numbers pad. 5° To much Extra work for me, when I can just do, 5* And , the Elite should understand that. For me 1 Extra poke, VS 5 Extra pokes on the key board. Not a idiot here, just lazy. Perhaps a keyboard shortcut is in order. P.S. My apologies for inadvertently referring to you as an idiot. I'll add you to the lazy column instead. Settle down, "Richard"!
[Re: Sport440]
#1826350
05/14/15 12:48 AM
05/14/15 12:48 AM
Posts: 1,845 Tampa
DusterDave
Tampa
Doesn't work for me. Someone else told me the "degree" key was beside the "any" key but I haven't been able to find it. Try This; Push/hold the Alt key, then type 0176 on the Far right numeral pad, then release. And Wallya ° ° :-} Adding the 0 to the 176 gives me a funky symbol. ALT and 167 on the keypad works for me.
