Reproduction Battery I.D #1822296
05/08/15 11:22 PM
05/08/15 11:22 PM
Oakville.ON,Canada
hemi_rtdave Offline OP
Oakville.ON,Canada
Please forgive me!!
Its been ages since I bought my red cap battery. How can I tell if its a maintenance free or not?
Re: Reproduction Battery I.D [Re: hemi_rtdave] #1822321
05/08/15 11:54 PM
05/08/15 11:54 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
The maintenance free battery has non-removable caps{as in glued on}..
Re: Reproduction Battery I.D [Re: hemi_rtdave] #1822418
05/09/15 02:15 AM
05/09/15 02:15 AM
Great White North
Furyman Offline
Furyman  Offline
Great White North
they are date coded on the top of the post as well.
"Long Live Mopars"
Re: Reproduction Battery I.D [Re: Furyman] #1822435
05/09/15 02:49 AM
05/09/15 02:49 AM
Oakville.ON,Canada
Oakville.ON,Canada
My red caps are removable! But looking inside it appears to be some sort of "other" container ? How much would this thing weigh when properly filled?
Re: Reproduction Battery I.D [Re: hemi_rtdave] #1822585
05/09/15 12:21 PM
05/09/15 12:21 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I think all of the reproduction batteries are maintenance free, and only one brand has screw off caps, and even then that is just for looks, so a judge can unscrew them.
Re: Reproduction Battery I.D [Re: hemi_rtdave] #1822688
05/09/15 02:46 PM
05/09/15 02:46 PM
Wahoo Nebr
vette1986 Offline
vette1986  Offline
Wahoo Nebr
Yes they are all gel and you do not need to add any water to them ever. Trust me I did!!
1969.5 A12 Bee EV2
1971 Charger RT
1973 Duster tubbed 500 low deck 10.90 monster
3 440 polara vert projects
Re: Reproduction Battery I.D [Re: 71birdJ68] #1822733
05/09/15 03:46 PM
05/09/15 03:46 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I had a few of the early repros red cap Mopar batteries from IIRC NewCastle Battery, they were shipped "dry", you had to add acid, and slow charge for 24 hrs before use...they always ended up dieing a quick death or leaking/venting making a mess...I'd get a newer gel cell repro, but if the OP insists on using what he has, just open the caps, if you see lead cell plates, then you'll need to fill with battery acid
Mike
Re: Reproduction Battery I.D [Re: DAYCLONA] #1822869
05/09/15 07:15 PM
05/09/15 07:15 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
So while we are on the subject, I know there was a post recently about the Group 27 batteries drying up ( no pun intended ).
Is there still a source for them.
I know Fred Gilmore used to carry them..I got one 7 years ago or so from him and its still alive.
I haven't talked to Fred in some time but I have a friend who needs one.
Is Fred still the go to guy ?
thanks in advance.
Re: Reproduction Battery I.D [Re: mccannix] #1823097
05/10/15 12:21 AM
05/10/15 12:21 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
thanks in advance.
Terry, AFAIK Fred Gilmore has no more batteries, unless he's signed on to another vendor?, Summit Racing no longer carries the line, Mancini Racing has some, the only other source for a quality battery is...
Re: Reproduction Battery I.D [Re: DAYCLONA] #1823122
05/10/15 01:03 AM
05/10/15 01:03 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Thanks for taking the time to find that Mike.
I'll definately get a hold of them
Re: Reproduction Battery I.D [Re: DAYCLONA] #1823135
05/10/15 01:26 AM
05/10/15 01:26 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Mike
Mike,I must have been lucky,first wet New Castle Group 27 was put in my bird when I finished it in 1992,lasted 12 yrs,the second sealed one is still in the car,picture from 94 ! shruggy
Re: Reproduction Battery I.D [Re: 62maxwgn] #1823349
05/10/15 12:25 PM
05/10/15 12:25 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Mike
EDIT: I see Fred Gilmore posted a few posts today saying that TurboStart may partner with Remy Battery to continue the production? there are other AGM repro battery sources in the meantime
Mike
Re: Reproduction Battery I.D [Re: DAYCLONA] #1825087
05/12/15 05:48 PM
05/12/15 05:48 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I cut mine apart once it died & added a Odyssey light weight racing battery inside. Not a race car, but it did go from like 54 lbs down to 18 lbs. It has more cranking amps & turns over much faster now than the re-pop Mopar red top batteries do.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Reproduction Battery I.D [Re: 6PKRTSE] #1825088
05/12/15 05:50 PM
05/12/15 05:50 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
From the top in my car.
