Re: Reproduction Battery I.D
[Re: hemi_rtdave]
#1822688
05/09/15 02:46 PM
05/09/15 02:46 PM
Posts: 1,347 Wahoo Nebr
vette1986
Wahoo Nebr
Yes they are all gel and you do not need to add any water to them ever. Trust me I did!!
1969.5 A12 Bee EV2 1971 Charger RT 1973 Duster tubbed 500 low deck 10.90 monster 3 440 polara vert projects
[Re: 71birdJ68]
#1822733
05/09/15 03:46 PM
05/09/15 03:46 PM
Posts: 18,153 Mass
DAYCLONA
Mass
I think all of the reproduction batteries are maintenance free, and only one brand has screw off caps, and even then that is just for looks, so a judge can unscrew them. I had a few of the early repros red cap Mopar batteries from IIRC NewCastle Battery, they were shipped "dry", you had to add acid, and slow charge for 24 hrs before use...they always ended up dieing a quick death or leaking/venting making a mess...I'd get a newer gel cell repro, but if the OP insists on using what he has, just open the caps, if you see lead cell plates, then you'll need to fill with battery acid Mike
[Re: mccannix]
#1823097
05/10/15 12:21 AM
05/10/15 12:21 AM
Posts: 18,153 Mass
DAYCLONA
Mass
So while we are on the subject, I know there was a post recently about the Group 27 batteries drying up ( no pun intended ). Is there still a source for them. I know Fred Gilmore used to carry them..I got one 7 years ago or so from him and its still alive. I haven't talked to Fred in some time but I have a friend who needs one. Is Fred still the go to guy ? thanks in advance. Terry, AFAIK Fred Gilmore has no more batteries, unless he's signed on to another vendor?, Summit Racing no longer carries the line, Mancini Racing has some, the only other source for a quality battery is...
[Re: DAYCLONA]
#1823135
05/10/15 01:26 AM
05/10/15 01:26 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
I think all of the reproduction batteries are maintenance free, and only one brand has screw off caps, and even then that is just for looks, so a judge can unscrew them. I had a few of the early repros red cap Mopar batteries from IIRC NewCastle Battery, they were shipped "dry", you had to add acid, and slow charge for 24 hrs before use...they always ended up dieing a quick death or leaking/venting making a mess...I'd get a newer gel cell repro, but if the OP insists on using what he has, just open the caps, if you see lead cell plates, then you'll need to fill with battery acid Mike Mike,I must have been lucky,first wet New Castle Group 27 was put in my bird when I finished it in 1992,lasted 12 yrs,the second sealed one is still in the car,picture from 94 !
[Re: 62maxwgn]
#1823349
05/10/15 12:25 PM
05/10/15 12:25 PM
Posts: 18,153 Mass
DAYCLONA
Mass
I think all of the reproduction batteries are maintenance free, and only one brand has screw off caps, and even then that is just for looks, so a judge can unscrew them. I had a few of the early repros red cap Mopar batteries from IIRC NewCastle Battery, they were shipped "dry", you had to add acid, and slow charge for 24 hrs before use...they always ended up dieing a quick death or leaking/venting making a mess...I'd get a newer gel cell repro, but if the OP insists on using what he has, just open the caps, if you see lead cell plates, then you'll need to fill with battery acid Mike Mike,I must have been lucky,first wet New Castle Group 27 was put in my bird when I finished it in 1992,lasted 12 yrs,the second sealed one is still in the car,picture from 94 ! EDIT: I see Fred Gilmore posted a few posts today saying that TurboStart may partner with Remy Battery to continue the production? there are other AGM repro battery sources in the meantime Mike
[Re: DAYCLONA]
#1825087
05/12/15 05:48 PM
05/12/15 05:48 PM
Posts: 4,540 Motor City
6PKRTSE
Motor City
I cut mine apart once it died & added a Odyssey light weight racing battery inside. Not a race car, but it did go from like 54 lbs down to 18 lbs. It has more cranking amps & turns over much faster now than the re-pop Mopar red top batteries do.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
