Re: Milodon dual line oil pump block gasket
[Re: sc301v]
#1820347
05/06/15 05:15 PM
05/06/15 05:15 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Do you guys run a gasket or just the oring or both on the block on a dual line milodon pump. I just put a new pump on and used a superperformance gasket and left the o ring in the pump and it is leaking pretty good.
If memory serves me right i normally just use the o ring and no gaskets and no problems. I would use either or but not both together. My motor was put together some time ago and used just the o-ring. Next time around I will use just the gasket #1306 (.031" Green HCF material). When you pull it back apart inspect the o-ring to be sure it was located properly and there are no nicks or tears on it if you decide to go the o-ring route.
[Re: sc301v]
#1820906
05/07/15 10:03 AM
05/07/15 10:03 AM
Posts: 2,933 A shed in England
Tig
A shed in England
We use both, gasket between block and sandwich plate and o ring between pump and sandwich plate. HTH's. Edit: What block is this? Indy block doesn't need the sandwich plate and we just use the o ring.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: roadhazard]
#1820981
05/07/15 12:31 PM
05/07/15 12:31 PM
Posts: 993 Addison,IL
OUTLAWSSAA
Addison,IL
Cometic part# C5604-032 $4.00ea Does quoting somebody's part number help the OP with his question If you read the original question, he's asking if we use a gasket. By giving him the part# I'm telling him I do use a gasket. Pretty simple.
[Re: Stanton]
#1821039
05/07/15 01:56 PM
05/07/15 01:56 PM
Tig
A shed in England
O-rings only between pump and cover. O-ring only between block and pump if using the Milodon pump. If you use the "sandwich plate" then you use a gasket between the block and plate and another gasket between the plate and pump. OOPs Never done it that way but never had any issues either Milodon billet pumps #21814, if that makes any difference.
