Milodon dual line oil pump block gasket #1820178
05/06/15 12:52 PM
05/06/15 12:52 PM
Kentucky
sc301v Offline OP
sc301v  Offline OP
Kentucky
Do you guys run a gasket or just the oring or both on the block on a dual line milodon pump. I just put a new pump on and used a superperformance gasket and left the o ring in the pump and it is leaking pretty good.
If memory serves me right i normally just use the o ring and no gaskets and no problems.
Re: Milodon dual line oil pump block gasket [Re: sc301v] #1820258
05/06/15 03:11 PM
05/06/15 03:11 PM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
popcorn
2011 Drag Pak Challenger
Re: Milodon dual line oil pump block gasket [Re: sc301v] #1820278
05/06/15 03:33 PM
05/06/15 03:33 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
Cometic part# C5604-032 $4.00ea
Re: Milodon dual line oil pump block gasket [Re: sc301v] #1820347
05/06/15 05:15 PM
05/06/15 05:15 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I would use either or but not both together. My motor was put together some time ago and used just the o-ring. Next time around I will use just the gasket #1306 (.031" Green HCF material).
When you pull it back apart inspect the o-ring to be sure it was located properly and there are no nicks or tears on it if you decide to go the o-ring route.
Re: Milodon dual line oil pump block gasket [Re: OUTLAWSSAA] #1820351
05/06/15 05:17 PM
05/06/15 05:17 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Does quoting somebody's part number help the OP with his question shruggy
Re: Milodon dual line oil pump block gasket [Re: roadhazard] #1820390
05/06/15 06:07 PM
05/06/15 06:07 PM
Kentucky
sc301v Offline OP
sc301v  Offline OP
Kentucky
I am gonna yank it off tonight.. I will probably go with just gasket cause of the quality of the gasket.. Much better than a stock gasket.
Re: Milodon dual line oil pump block gasket [Re: sc301v] #1820906
05/07/15 10:03 AM
05/07/15 10:03 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
We use both, gasket between block and sandwich plate and o ring between pump and sandwich plate. HTH's. up
Edit: What block is this? Indy block doesn't need the sandwich plate and we just use the o ring.
Re: Milodon dual line oil pump block gasket [Re: sc301v] #1820964
05/07/15 11:49 AM
05/07/15 11:49 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
O-rings only between pump and cover. O-ring only between block and pump if using the Milodon pump. If you use the "sandwich plate" then you use a gasket between the block and plate and another gasket between the plate and pump.
Re: Milodon dual line oil pump block gasket [Re: roadhazard] #1820981
05/07/15 12:31 PM
05/07/15 12:31 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
If you read the original question, he's asking if we use a gasket. By giving him the part# I'm telling him I do use a gasket. Pretty simple.
Re: Milodon dual line oil pump block gasket [Re: Stanton] #1821039
05/07/15 01:56 PM
05/07/15 01:56 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
OOPs blush Never done it that way but never had any issues either shruggy Milodon billet pumps #21814, if that makes any difference.
