Which powersteering pump on a 69 RT Charger?
#1818048
05/03/15 10:38 PM
05/03/15 10:38 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
Saginaw or Federal? It's an A/C car if it matters. St. Louis built 927 SPD, auto, B5.
Careful, your character's showing!
Re: Which powersteering pump on a 69 RT Charger?
[Re: mopar346]
#1818159
05/04/15 12:37 AM
05/04/15 12:37 AM
mopar346
Any pictures? What does the TRW look like the Federal with different mounting? Or is that just another style of Federal?
[Re: mopar346]
#1819260
05/05/15 12:03 PM
05/05/15 12:03 PM
Posts: 318 Iowa
ratroaster
Iowa
[Re: ratroaster]
#1819352
05/05/15 02:41 PM
05/05/15 02:41 PM
Posts: 1,307 Minnesota
PocketThunder
Minnesota
Where can I get one of these pumps? Where is the best place? Parts store like napa, etc? I have a core for exchange.
Paul
69 Charger R/T. California car, 99 99 Special Order paint car, Omaha Orange. Original Paint, Interior, drivetrain, etc..
[Re: mopar346]
#1819761
05/05/15 11:21 PM
05/05/15 11:21 PM
mopar346
It appears from the picture that the pumps are different, look at the bolt that retains the reservoir, it's in a different location.
So it there a general rule? TRW 68 and back? 69-? B-bodies except Hemis Federal? C-bodies saginaw?
I pretty sure the one on my AAR is a Federal as did a 70 Dart I pulled a spare off of. Best I can tell a 68 SB Coronet I have has a TRW on it.
The above picture show the same mounts for the bracket but the ones I have that I think are TRWs have a different mount. The first picture I attached is I believe a TRW, the second is what I believe is a Federal.
Thanks for the input folks.
[Re: mopar346]
#1819917
05/06/15 01:29 AM
05/06/15 01:29 AM
Posts: 318 Iowa
ratroaster
Iowa
The first pic in your post is a Saginaw pump(oval fill top). The second pic you posted appears to be a TRW pump with a Federal cap on it. The TRW caps and federal caps will interchange. Normally the federal caps had "ears" and the TRW's were round. The TRW and federal pumps are real similar if you don't know what to look for. The easiest way to tell is the difference in the reservoir's as I posted earlier. Most TRW's pumps were '68 and earlier so after '68 the majority got Saginaw and Federal. If you don't know your cars history, take your pick.
[Re: mopar346]
#1819925
05/06/15 01:37 AM
05/06/15 01:37 AM
Posts: 318 Iowa
ratroaster
Iowa
It appears from the picture that the pumps are different, look at the bolt that retains the reservoir, it's in a different location. mopar346- the TRW and federal pumps are totally different. They are just real close to each other and easier to identify by the reservoir's. The reservoirs will not interchange.
[Re: mopar346]
#1820029
05/06/15 10:33 AM
05/06/15 10:33 AM
mopar346
Thank you for the info, I'll try to sort it all out. More reference pictures and studying I guess.
[Re: mopar346]
#1820965
05/07/15 11:49 AM
05/07/15 11:49 AM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
On a '69 Charger R/T equipped with a 440, the pump should be a Saginaw as pictured ( the cooler was with cars equipped with a 3.55/3.54 to 4.10. The 3.23 cars didn't. Now, if the R/T was equipped with a 426 HEMI, it would have the Federal pump...
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: mopar346]
#1821328
05/07/15 09:55 PM
05/07/15 09:55 PM
mopar346
Thank you, any pictures of the backside backet?
[Re: mopar346]
#1825771
05/13/15 02:32 PM
05/13/15 02:32 PM
Posts: 511 South Georgia
tx9cuda
South Georgia
1971 BS23H1B
[Re: Dixie]
#1826327
05/14/15 12:29 AM
05/14/15 12:29 AM
Posts: 318 Iowa
ratroaster
Iowa
On a '69 Charger R/T equipped with a 440, the pump should be a Saginaw as pictured ( the cooler was with cars equipped with a 3.55/3.54 to 4.10. The 3.23 cars didn't. Now, if the R/T was equipped with a 426 HEMI, it would have the Federal pump... I've seen a couple survivor '69 440's with Federal pumps. I got some pictures somewhere. No way to know if no history of the car. I agree that most were the Saginaw.
[Re: tx9cuda]
#1834244
05/25/15 11:40 PM
05/25/15 11:40 PM
mopar346
Thank you, any pictures of the backside backet? Thanks Bryan, I guess I can use your's as a reference when I get ready to change it. Remind me to take plenty of pictures next time I'm near the car. I'm running the later saginaw pump on it right now, a carry over from the 77 engine I dropped in it.
