Which powersteering pump on a 69 RT Charger? #1818048
05/03/15 10:38 PM
05/03/15 10:38 PM
mopar346 Offline OP
Let me tell ya about fat chicks!
mopar346  Offline OP
Saginaw or Federal?
It's an A/C car if it matters. St. Louis built 927 SPD, auto, B5. grin
Careful, your character's showing!
Re: Which powersteering pump on a 69 RT Charger? [Re: mopar346] #1818150
05/04/15 12:27 AM
05/04/15 12:27 AM
North Carolina
469runner Offline
469runner  Offline
North Carolina
Mine has a TRW.
Re: Which powersteering pump on a 69 RT Charger? [Re: mopar346] #1818158
05/04/15 12:36 AM
05/04/15 12:36 AM
NW Arkansas
challengersteve Offline
NW Arkansas
Hello, as far as I know it should be a Saginaw as the TRW-Thompson pumps were 68 and back. The federal pump was used on the big block C Bodies and the 426 Hemi cars but not the 440 B Bodies.
Re: Which powersteering pump on a 69 RT Charger? [Re: mopar346] #1818159
05/04/15 12:37 AM
05/04/15 12:37 AM
mopar346 Offline OP
mopar346  Offline OP
Any pictures? What does the TRW look like the Federal with different mounting? Or is that just another style of Federal?
Re: Which powersteering pump on a 69 RT Charger? [Re: mopar346] #1819260
05/05/15 12:03 PM
05/05/15 12:03 PM
Iowa
ratroaster Offline
ratroaster  Offline
Iowa
Re: Which powersteering pump on a 69 RT Charger? [Re: ratroaster] #1819352
05/05/15 02:41 PM
05/05/15 02:41 PM
Minnesota
PocketThunder Offline
Minnesota
Where can I get one of these pumps? Where is the best place? Parts store like napa, etc? I have a core for exchange.
Paul
69 Charger R/T. California car, 99 99 Special Order paint car, Omaha Orange. Original Paint, Interior, drivetrain, etc..
Re: Which powersteering pump on a 69 RT Charger? [Re: mopar346] #1819545
05/05/15 07:07 PM
05/05/15 07:07 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
The last one I bought was from NAPA.The pump is the same but the tank is different.Just clean up your origional and swap them. wrench
Re: Which powersteering pump on a 69 RT Charger? [Re: mopar346] #1819761
05/05/15 11:21 PM
05/05/15 11:21 PM
mopar346 Offline OP
mopar346  Offline OP
It appears from the picture that the pumps are different, look at the bolt that retains the reservoir, it's in a different location.
So it there a general rule? TRW 68 and back? 69-? B-bodies except Hemis Federal? C-bodies saginaw?
I pretty sure the one on my AAR is a Federal as did a 70 Dart I pulled a spare off of. Best I can tell a 68 SB Coronet I have has a TRW on it.
The above picture show the same mounts for the bracket but the ones I have that I think are TRWs have a different mount. The first picture I attached is I believe a TRW, the second is what I believe is a Federal.
Thanks for the input folks.
Re: Which powersteering pump on a 69 RT Charger? [Re: mopar346] #1819917
05/06/15 01:29 AM
05/06/15 01:29 AM
Iowa
ratroaster Offline
ratroaster  Offline
Iowa
The first pic in your post is a Saginaw pump(oval fill top). The second pic you posted appears to be a TRW pump with a Federal cap on it. The TRW caps and federal caps will interchange. Normally the federal caps had "ears" and the TRW's were round. The TRW and federal pumps are real similar if you don't know what to look for. The easiest way to tell is the difference in the reservoir's as I posted earlier.
Most TRW's pumps were '68 and earlier so after '68 the majority got Saginaw and Federal. If you don't know your cars history, take your pick.
Re: Which powersteering pump on a 69 RT Charger? [Re: mopar346] #1819925
05/06/15 01:37 AM
05/06/15 01:37 AM
Iowa
ratroaster Offline
ratroaster  Offline
Iowa
mopar346- the TRW and federal pumps are totally different. They are just real close to each other and easier to identify by the reservoir's. The reservoirs will not interchange.
Re: Which powersteering pump on a 69 RT Charger? [Re: mopar346] #1820029
05/06/15 10:33 AM
05/06/15 10:33 AM
mopar346 Offline OP
mopar346  Offline OP
Thank you for the info, I'll try to sort it all out. More reference pictures and studying I guess.
Re: Which powersteering pump on a 69 RT Charger? [Re: mopar346] #1820965
05/07/15 11:49 AM
05/07/15 11:49 AM
Houston, Tx
hemi68charger Offline
Houston, Tx
On a '69 Charger R/T equipped with a 440, the pump should be a Saginaw as pictured ( the cooler was with cars equipped with a 3.55/3.54 to 4.10. The 3.23 cars didn't. Now, if the R/T was equipped with a 426 HEMI, it would have the Federal pump...
Troy
Houston Mopar Connection Club
Re: Which powersteering pump on a 69 RT Charger? [Re: mopar346] #1821328
05/07/15 09:55 PM
05/07/15 09:55 PM
mopar346 Offline OP
mopar346  Offline OP
Thank you, any pictures of the backside backet?
Re: Which powersteering pump on a 69 RT Charger? [Re: mopar346] #1824933
05/12/15 01:47 PM
05/12/15 01:47 PM
france
jose jones Offline
jose jones  Offline
france
The one with the round neck is generally found on 68 models the oval neck on 69 models the hoses are also didderent
Re: Which powersteering pump on a 69 RT Charger? [Re: mopar346] #1825771
05/13/15 02:32 PM
05/13/15 02:32 PM
South Georgia
tx9cuda Offline
tx9cuda  Offline
South Georgia
1971 BS23H1B
Re: Which powersteering pump on a 69 RT Charger? [Re: hemi68charger] #1826120
05/13/15 09:51 PM
05/13/15 09:51 PM
Ball Ground, Georgia
Dixie Offline
Dixie  Offline
iagree
Dixie Restoration Parts
Phone -(770) 975-9898
Phone Hours: M-F 10am-5pm EST
website: www.dixierestorationparts.com
email: mail@dixierestorationparts.com
Veteran owned small business
The Best Parts at a Fair Price.
Re: Which powersteering pump on a 69 RT Charger? [Re: Dixie] #1826327
05/14/15 12:29 AM
05/14/15 12:29 AM
Iowa
ratroaster Offline
ratroaster  Offline
Iowa
I've seen a couple survivor '69 440's with Federal pumps. I got some pictures somewhere. No way to know if no history of the car. I agree that most were the Saginaw.
Re: Which powersteering pump on a 69 RT Charger? [Re: tx9cuda] #1834244
05/25/15 11:40 PM
05/25/15 11:40 PM
mopar346 Offline OP
mopar346  Offline OP
Thanks Bryan, I guess I can use your's as a reference when I get ready to change it. Remind me to take plenty of pictures next time I'm near the car. I'm running the later saginaw pump on it right now, a carry over from the 77 engine I dropped in it.
