904 fluid leak from tailshaft
#1814557
04/29/15 01:38 PM
04/29/15 01:38 PM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
Hey guys I've got a pretty decent leak coming out of the tailshaft of my SS Stratus. Getting trans fluid all over the under side of the car after a pass. I've put a new bushing and seal in it but that didn't change anything. It has a aluminum driveshaft in it with a MW chromemoly yoke. Any ideas?
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: 904 fluid leak from tailshaft
[Re: Jacob Pitt]
#1814595
04/29/15 03:01 PM
04/29/15 03:01 PM
Jacob Pitt
Mansfield, Tx
Yes it is vented, in fact it had a bid overflow catch can on it and I removed it and installed the typical vent at the rear and top of the case. It didn't seem to slow down the leak.
[Re: MR_P_BODY]
#1814666
04/29/15 05:15 PM
04/29/15 05:15 PM
Jacob Pitt
Mansfield, Tx
Are you sure its not over filled.. is it the stock dip stick It's one of those flexible dipsticks. I have tried two different breather setups with no change, and two different rear seals with no change. It starts leaking on it's very first pass.
[Re: Jacob Pitt]
#1814671
04/29/15 05:20 PM
04/29/15 05:20 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Are you sure its not over filled.. is it the stock dip stick It's one of those flexible dipsticks. I have tried two different breather setups with no change, and two different rear seals with no change. It starts leaking on it's very first pass. It can be a over fill issue... I dont know the measured height of a 904.. but see if you can check that ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: mrsmallblock]
#1814702
04/29/15 06:09 PM
04/29/15 06:09 PM
MR_P_BODY
Make sure the yoke plug isn't leaking....
Howard Mrsmallblock Very true.. the center of the yoke has a plug in it on the U-joint side ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: MR_P_BODY]
#1815208
04/30/15 09:18 AM
04/30/15 09:18 AM
Jacob Pitt
Mansfield, Tx
Howard Mrsmallblock Very true.. the center of the yoke has a plug in it on the U-joint side Even on a aftermarket yoke?
[Re: Jacob Pitt]
#1815225
04/30/15 10:13 AM
04/30/15 10:13 AM
MR_P_BODY
Howard Mrsmallblock Very true.. the center of the yoke has a plug in it on the U-joint side Even on a aftermarket yoke? Yes... on most ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: Jacob Pitt]
#1818298
05/04/15 09:57 AM
05/04/15 09:57 AM
Jacob Pitt
Mansfield, Tx
I was under the car yesterday and rechecked the yoke. It appears to be all intact. I think I will drain the fluid and refill refill it keeping it lower to see if it helps. Maybe it's overfilled?
[Re: Jacob Pitt]
#1818566
05/04/15 03:41 PM
05/04/15 03:41 PM
Posts: 25,982 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The dipstick shows the correct level....checked warm while idling in Neutral.
