904 fluid leak from tailshaft #1814557
04/29/15 01:38 PM
04/29/15 01:38 PM
Mansfield, Tx
Jacob Pitt Offline OP
Mansfield, Tx
Hey guys I've got a pretty decent leak coming out of the tailshaft of my SS Stratus. Getting trans fluid all over the under side of the car after a pass. I've put a new bushing and seal in it but that didn't change anything. It has a aluminum driveshaft in it with a MW chromemoly yoke. Any ideas?
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: 904 fluid leak from tailshaft [Re: Jacob Pitt] #1814587
04/29/15 02:53 PM
04/29/15 02:53 PM
dogdays Offline
dogdays  Offline
Is the transmission vented?
R.
Re: 904 fluid leak from tailshaft [Re: Jacob Pitt] #1814589
04/29/15 02:55 PM
04/29/15 02:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I would think vent or a bent tailshaft
wave
Re: 904 fluid leak from tailshaft [Re: Jacob Pitt] #1814595
04/29/15 03:01 PM
04/29/15 03:01 PM
Mansfield, Tx
Mansfield, Tx
Yes it is vented, in fact it had a bid overflow catch can on it and I removed it and installed the typical vent at the rear and top of the case. It didn't seem to slow down the leak.
14x Track Champ
Re: 904 fluid leak from tailshaft [Re: Jacob Pitt] #1814597
04/29/15 03:04 PM
04/29/15 03:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Are you sure its not over filled.. is it the stock dip stick
wave
Re: 904 fluid leak from tailshaft [Re: Jacob Pitt] #1814619
04/29/15 03:34 PM
04/29/15 03:34 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
I had mine vented at the rear of the case but used a sintered type of vent. That caused me hell and leaks. It also made it difficult to get the right amount of fluid in the trans.I changed to a free breathing spring loaded type and it quit leaking and it was easer to check the level. I now have the line going into a catch can and its worked well
Re: 904 fluid leak from tailshaft [Re: Jacob Pitt] #1814638
04/29/15 04:04 PM
04/29/15 04:04 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Check to balancing of the driveshaft. If it is out, it will ruin the seal.
Re: 904 fluid leak from tailshaft [Re: MR_P_BODY] #1814666
04/29/15 05:15 PM
04/29/15 05:15 PM
Mansfield, Tx
Mansfield, Tx
wave
It's one of those flexible dipsticks. I have tried two different breather setups with no change, and two different rear seals with no change. It starts leaking on it's very first pass.
14x Track Champ
Re: 904 fluid leak from tailshaft [Re: Jacob Pitt] #1814671
04/29/15 05:20 PM
04/29/15 05:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
wave
It can be a over fill issue... I dont know the measured height
of a 904.. but see if you can check that
wave
Re: 904 fluid leak from tailshaft [Re: MR_P_BODY] #1814699
04/29/15 06:04 PM
04/29/15 06:04 PM
Dillsburg, PA
mrsmallblock Offline
Dillsburg, PA
Make sure the yoke plug isn't leaking....
Howard
Mrsmallblock
Re: 904 fluid leak from tailshaft [Re: mrsmallblock] #1814702
04/29/15 06:09 PM
04/29/15 06:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Howard
Mrsmallblock
Very true.. the center of the yoke has a plug in it on the
U-joint side
wave
Re: 904 fluid leak from tailshaft [Re: MR_P_BODY] #1815208
04/30/15 09:18 AM
04/30/15 09:18 AM
Mansfield, Tx
Mansfield, Tx
Howard
Mrsmallblock
U-joint side
wave
Even on a aftermarket yoke?
14x Track Champ
Re: 904 fluid leak from tailshaft [Re: Jacob Pitt] #1815225
04/30/15 10:13 AM
04/30/15 10:13 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Howard
Mrsmallblock
U-joint side
wave
Yes... on most
wave
Re: 904 fluid leak from tailshaft [Re: Jacob Pitt] #1815328
04/30/15 12:36 PM
04/30/15 12:36 PM
Mansfield, Tx
Mansfield, Tx
I'll check it out.
14x Track Champ
Re: 904 fluid leak from tailshaft [Re: Jacob Pitt] #1815582
04/30/15 05:23 PM
04/30/15 05:23 PM
Dillsburg, PA
Dillsburg, PA
Let us know what you find....
Howard
Mrsmallblock
Re: 904 fluid leak from tailshaft [Re: Jacob Pitt] #1818298
05/04/15 09:57 AM
05/04/15 09:57 AM
Mansfield, Tx
Mansfield, Tx
I was under the car yesterday and rechecked the yoke. It appears to be all intact. I think I will drain the fluid and refill refill it keeping it lower to see if it helps. Maybe it's overfilled?
14x Track Champ
Re: 904 fluid leak from tailshaft [Re: Jacob Pitt] #1818566
05/04/15 03:41 PM
05/04/15 03:41 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The dipstick shows the correct level....checked warm while idling in Neutral.
Re: 904 fluid leak from tailshaft [Re: Jacob Pitt] #1818597
05/04/15 04:32 PM
05/04/15 04:32 PM
Mansfield, Tx
Mansfield, Tx
Yes
14x Track Champ
Re: 904 fluid leak from tailshaft [Re: Jacob Pitt] #1818626
05/04/15 05:06 PM
05/04/15 05:06 PM
Out West
408strokerdart Offline
Out West
Seems like you have checked all of the usual suspects. Those flexible dip sticks are nortoius for being wrong. I replaced mine on my glide because it was so far off.
