Solid roller or solid flat tappet 528 Hemi?
#1809055
04/21/15 11:15 PM
04/21/15 11:15 PM
Posts: 73 Toronto,Canada
wkeggenhoff
Toronto,Canada
Time to upgrade came from hydralic to something else I guess after having a lifter fall apart
Ray Barton says solid flat tappet, package he has is streetable for $1100(cam, special lifters,push rods, springs retainers etc. Tim Banning (FHO)says you can make a solid roller live on street.
Don't know which way to go ? Any recomendations ?
Street driven 69 charger 5spd, 3:73 gear. Currently has single 870 cfm dual plane instake.Manual brakes. Want this thing to cam over nicely and sound like a hemi should.
69 dodge charger,528 Hemi,Keisler TKO 5spd, Mosier 60 rear end
Re: Solid roller or solid flat tappet 528 Hemi?
[Re: wkeggenhoff]
#1809112
04/22/15 12:21 AM
04/22/15 12:21 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Contact Chase Knight from Crane Cams, he put together a solid roller for me that has a wide lobe separation for good idle and pushrod oiling. 242@.050 and .620 lift 112 lsa....but this is on a 572 with low compression. Bullet cams can do something similar depending on all of your specifics. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: Dragula]
#1809162
04/22/15 01:51 AM
04/22/15 01:51 AM
Posts: 795 Glendale Az
Darryls-Demon
Glendale Az
One, you should be posting in a different section, this is the RACE section.
Two, the solid flat tappet is better because all the roller lifters as of late have very high failure rates....IE, lack of quality control. I am sure Barton told you that when you talked with him. If you go roller, better be prepared to send them back for checking regularly or risk a bigger problem. Wow don`t tell that to the comp solid roller lifters in my old W2 motor, they have by now at least 12.500 street miles and right around 65 1/4 drag strip on them and have never been rebuilt. The first 5000 miles the cam in the motor was small at .630 lift. The cam that is in it now .700 lift. Some company`s do have a quality control problem.
[Re: Darryls-Demon]
#1809190
04/22/15 03:16 AM
04/22/15 03:16 AM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Two, the solid flat tappet is better because all the roller lifters as of late have very high failure rates....IE, lack of quality control. I am sure Barton told you that when you talked with him. If you go roller, better be prepared to send them back for checking regularly or risk a bigger problem. Wow don`t tell that to the comp solid roller lifters in my old W2 motor, they have by now at least 12.500 street miles and right around 65 1/4 drag strip on them and have never been rebuilt. The first 5000 miles the cam in the motor was small at .630 lift. The cam that is in it now .700 lift. Some company`s do have a quality control problem. Ya me too......lots of street miles and several passes in 8 years with one lifter rebuild but everything has a life span just haven't found mine yet and hopefully never will.
[Re: wkeggenhoff]
#1809280
04/22/15 10:58 AM
04/22/15 10:58 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
If you buy GOOD roller lifters and use good (correct) springs, you shouldn't have any problems. My set of Isky Red Zone solid rollers were new in 2006. I've sent them back to Isky twice since then for inspection and they have not needed anything.
I'd go w/ a solid roller...no doubt about it.
[Re: J_BODY]
#1809306
04/22/15 11:30 AM
04/22/15 11:30 AM
an8sec70cuda
I think I've heard of more flat tappet failures in the last few years than rollers....
Nearly every modern engine on the road today has roller lifters or followers....
[Re: wkeggenhoff]
#1809978
04/23/15 08:11 AM
04/23/15 08:11 AM
Posts: 1,629 pa
572charger
pa
i did a 528 hemi last year for a friend, i used a hydralic roller cam from comp and lifters !! only down fall was i had to clearance the push rod holes in the heads because the lifters are taller ,xr280hr-10 sounds great , i ran it on a break in stand , he has not driven it yet the car is not done i will up date later this year
606 hemi pump gas best 9.60 at 142mph on motor 05 hemi daytona 1500 go-mango 4wd quadcab 2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
