Fuel Line Question for A12 Bee. #1796181
04/04/15 10:11 AM
04/04/15 10:11 AM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
In Restoration of an A12 Super Bee, what is the correct fuel line size from the Carter pump to the T at the Six pack setup. Year One says 5/16 but it seems odd since the lines coming from the tank and the tank hanger are 3/8. I know there is a vapor separator that goes in the line also. Can anyone elaborate?
Thanks.
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor
1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic
1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow
1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top
2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue
2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black
2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
Re: Fuel Line Question for A12 Bee. [Re: TimS] #1796182
04/04/15 10:27 AM
04/04/15 10:27 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Thanks.
Morning,
Yes that correct, 3/8" on the suction side of the mechanical pump and it's all 5/16" on the discharge side through the fuel pump mounted VS and then to the 6 pak. Don't worry... 5/16" is plenty.
Re: Fuel Line Question for A12 Bee. [Re: Challenger 1] #1796183
04/04/15 11:51 AM
04/04/15 11:51 AM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
Thanks.
Morning,
Thanks for verifying. Seems odd. I would have thought 3/8 to the 5/16 T fitting to the carbs. I looked at my 70 and it has 5/16. Never really paid any attention till we started fitting this A12 Bee.
Re: Fuel Line Question for A12 Bee. [Re: Challenger 1] #1796184
04/04/15 11:53 AM
04/04/15 11:53 AM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
Actually, no 440 cars have a 3/8" fuel line. The A12 sending unit has a 3/8" nipple same as a Hemi sending unit but the A12 fuel line from the gas tank to the carbs was 5/16". Only the Hemi's had 3/8" fuel line up to the fuel pump. All 440/426 cars have 5/16" from the fuel pump to the carbs. I used the Hemi fuel line to the pump on my A12 race car in the 70's and a couple of A12 restorations since then. It's just not OE Gold if that's your objective.
Re: Fuel Line Question for A12 Bee. [Re: RoadRunnerJD] #1796185
04/04/15 04:36 PM
04/04/15 04:36 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
That is correct, JD, I was an original purchaser in the spring of 69
and changed my fuel line to the pump with a 3/8" rubber hose.
Did it help, not sure it did, but I felt better.....
Joe
Re: Fuel Line Question for A12 Bee. [Re: TimS] #1804421
04/15/15 09:00 PM
04/15/15 09:00 PM
Falconer, NY
KatFysh Offline
KatFysh  Offline
Falconer, NY
I made another post and was directed here...My friend is restoring a '68 Charger 383, 4 barrel, auto..the person helping restore it accidentally,prematurely threw out the sending unit.. Would his be a single, 5/16" line? Or would there be a need for return line? I'm guessing it was a single line but want to find out for sure for him..if it's a dual line, what are the sizes?
When you decide to quit, THAT is the moment when you would've succeeded..
Re: Fuel Line Question for A12 Bee. [Re: TimS] #1804486
04/15/15 10:28 PM
04/15/15 10:28 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
383 car will be a 5/16" sender without a return line fitting
Re: Fuel Line Question for A12 Bee. [Re: gtx6970] #1805060
04/16/15 05:05 PM
04/16/15 05:05 PM
Falconer, NY
KatFysh Offline
KatFysh  Offline
Falconer, NY
up Thank you..
