Fuel Line Question for A12 Bee.
#1796181
04/04/15 10:11 AM
04/04/15 10:11 AM
Posts: 2,179 Walton, Indiana
TimS
Walton, Indiana
In Restoration of an A12 Super Bee, what is the correct fuel line size from the Carter pump to the T at the Six pack setup. Year One says 5/16 but it seems odd since the lines coming from the tank and the tank hanger are 3/8. I know there is a vapor separator that goes in the line also. Can anyone elaborate?
Thanks.
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor 1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic 1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow 1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top 2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue 2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black 2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
Re: Fuel Line Question for A12 Bee.
[Re: TimS]
#1796182
04/04/15 10:27 AM
04/04/15 10:27 AM
Challenger 1
Cincinnati, Ohio
Thanks.
Morning, Yes that correct, 3/8" on the suction side of the mechanical pump and it's all 5/16" on the discharge side through the fuel pump mounted VS and then to the 6 pak. Don't worry... 5/16" is plenty.
[Re: TimS]
#1804421
04/15/15 09:00 PM
04/15/15 09:00 PM
Posts: 9,116 Falconer, NY
KatFysh
Falconer, NY
I made another post and was directed here...My friend is restoring a '68 Charger 383, 4 barrel, auto..the person helping restore it accidentally,prematurely threw out the sending unit.. Would his be a single, 5/16" line? Or would there be a need for return line? I'm guessing it was a single line but want to find out for sure for him..if it's a dual line, what are the sizes?
When you decide to quit, THAT is the moment when you would've succeeded..
