broken 4-sp #1794768
04/02/15 08:43 AM
04/02/15 08:43 AM
Ia
4spdana Offline OP
4spdana  Offline OP
Ia
broke 3rd gear, i have a spare input .... so can i use any 833 23 spline cluster?
how do i identify the correct cluster?
i'll check scatter shield for alignment with a dial indicator on the clutch...... had done this a couple years ago, don't understand how or if it could change. will also look at pilot bushing.
any other ideas ?
Re: broken 4-sp [Re: 4spdana] #1794769
04/02/15 11:20 AM
04/02/15 11:20 AM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
That is 4th gear that is broke, looks to be a 2.47 close ratio 23 spline, so that is the cluster/input shaft you have to use.
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: broken 4-sp [Re: 64dodge572] #1794770
04/02/15 05:07 PM
04/02/15 05:07 PM
Ia
4spdana Offline OP
4spdana  Offline OP
Ia
its a 23 spline run-of-the-mill standard production 833, Liberty converted it to Face Plate.
i'll just look for a cluster on e-Bay , racing junk ect.....
Re: broken 4-sp [Re: 4spdana] #1794771
04/02/15 06:42 PM
04/02/15 06:42 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
It has to be from a 71-4 trans, I have used ones in stock.
FAX 937-947-4419
Re: broken 4-sp [Re: 64dodge572] #1794772
04/03/15 07:05 AM
04/03/15 07:05 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Kinda curious why you mention it's 4th gear that's broke. The trans doesn't even need the cluster gear in it for 4th gear to work.
1st, 2nd, 3rd gears are all screwed, with the input and cluster damage shown, but I don't see why the shift ring shouldn't engage the input for 4th.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: broken 4-sp [Re: Evil Spirit] #1794773
04/03/15 11:12 AM
04/03/15 11:12 AM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
I mentioned it was 4th because it was called 3rd gear.....The fact that it will go into 4th gear and "work" is kinda pointless since like you mentioned the trash run through the trans likely tore up more than just the cluster/input.
FAX 937-947-4419
Re: broken 4-sp [Re: Evil Spirit] #1794774
04/03/15 02:48 PM
04/03/15 02:48 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Do you have an engine with enough torque ... and enough gear ... to start off in 1:1 ???
Re: broken 4-sp [Re: 4spdana] #1794775
04/03/15 08:51 PM
04/03/15 08:51 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
You're gonna need a lot more than a cluster gear
I would tell you to scrap the whole idea of wasting any more of your money on face plating another 23 spline box but you seem to have your mind made up.Take it from someone that has torn up a few 23 spline boxes, stop wasting money on them and get a HEMI box
You can stop looking at what caused the carnage because it was traction, horsepower, and a hard hitting clutch.
Gus
64 Plymouth Savoy
Dana 60
Re: broken 4-sp [Re: JohnRR] #1794776
04/04/15 02:04 AM
04/04/15 02:04 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
And that matters why? I never suggested that he - or I - actually drive the car starting in 4th gear. I simply mentioned that 4th gear - in this case the input shaft face plate and the slide ring - didn't appear damaged. In a true 833 4 speed, the damaged area/gear on the input shaft (in the picture) that drives the cluster has NOTHING to do with 4th gear. The cluster itself has NOTHING to do with 4 gear - doesn't even need to be in the trans for 4th gear to operate -
if for some reason you choose to operate it that way.. Now, if it was an 833OD trans, in this case 3rd gear would be good, and 4th gear would be hurt - along with 1st and 2nd, although at that point most people call that gear OVERDRIVE, not 4th.
Re: broken 4-sp [Re: fourgearsavoy] #1794777
04/04/15 11:35 AM
04/04/15 11:35 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
<SNIP!>....Take it from someone that has torn up a few 23 spline boxes, stop wasting money on them and get a HEMI box
Gus
I've eaten more than a few 23-spline A833s with a healthy small block, road-course type use. Shucked teeth right off the countershaft and speed gears. Even built boxes with new (NOS '60s) gears, still ate 'em. This was in a light A-body, too. I was really bummed to have to walk away from the 3.09:1 first, but there was no other option.
18-spline or modern tranny swap. No other viable options. That's my 2¢.
Rick
Re: broken 4-sp [Re: Rick_Ehrenberg] #1801497
04/12/15 03:52 AM
04/12/15 03:52 AM
Seattle WA
RichV Offline
RichV  Offline
Seattle WA
Shot peening the replacement gears will increase there torque capacity. The compressive stress created by shot peening will decrease the tensile stress at the gear tooth root. I can not quote you a percent increase in torque capacity but this is used by Eaton on some of their transmissions to increase torque capacity.
