vac pump Mandrel drive question??? #179246
12/30/08 10:52 PM
12/30/08 10:52 PM
On the parachute mount
N
n20mstr Offline OP
n20mstr  Offline OP
N
do the Moroso drives have the pulleys "stacked" with a key way? this way they can be moved around to match up with the way your pump is mounted???
....BAD A$$ STREET CAR.....
Re: vac pump Mandrel drive question??? [Re: n20mstr] #179247
12/30/08 10:56 PM
12/30/08 10:56 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
yes
1.39 9.85 - 137 mph
Re: vac pump Mandrel drive question??? [Re: n20mstr] #179248
12/30/08 10:59 PM
12/30/08 10:59 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
Re: vac pump Mandrel drive question??? [Re: Ari440] #179249
12/30/08 11:00 PM
12/30/08 11:00 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
one belt for the altenater and the other for the vacume pump
you can see spacers the make the pullys lineup
1.39 9.85 - 137 mph
Re: vac pump Mandrel drive question??? [Re: Ari440] #179250
12/30/08 11:14 PM
12/30/08 11:14 PM
N
n20mstr Offline OP
n20mstr  Offline OP
N
thanks guys, the Moroso one looks nice
Re: vac pump Mandrel drive question??? [Re: n20mstr] #179251
12/30/08 11:23 PM
12/30/08 11:23 PM
Central So California
Broom Hilda Offline
Broom Hilda  Offline
Does the moroso unit go over the stock crank bolt? I am asking because the one I have uses the mandrel bolt to hold the dampner, but it keeps loosening up. So I am looking for another type or buliding my own. Thanks
Ron
Re: vac pump Mandrel drive question??? [Re: Broom Hilda] #179252
12/30/08 11:31 PM
12/30/08 11:31 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
the dampner is bolted down by the center bolt
6 alen bolts bolt the hub to the dampner
the long bolt threads into the hub
1.39 9.85 - 137 mph
Re: vac pump Mandrel drive question??? [Re: n20mstr] #179253
12/30/08 11:34 PM
12/30/08 11:34 PM
Colorado,U.S.A
4404dart Offline
4404dart  Offline
Colorado,U.S.A
Tony I just ordered all Moroso stuff. The 4 vane enhanced pump sounded like the ticket, so that's the way I went. This costs a few bucks, so I hope it's worth it? Dave.
Re: vac pump Mandrel drive question??? [Re: 4404dart] #179254
12/30/08 11:44 PM
12/30/08 11:44 PM
N
n20mstr Offline OP
n20mstr  Offline OP
N
i picked up a Star pump and all the parts needed, except for the drive...I have not ran a pump yet, its supposed to help a lot. We see what happens, theres also that second fogger im starting to collect parts for...
Re: vac pump Mandrel drive question??? [Re: Ari440] #179255
12/30/08 11:55 PM
12/30/08 11:55 PM
Broom Hilda Offline
Broom Hilda  Offline
Thanks, sounds like the one I need. I'll order one tommorow.
Re: vac pump Mandrel drive question??? [Re: Broom Hilda] #179256
12/31/08 12:32 AM
12/31/08 12:32 AM
Out West
408strokerdart Offline
Out West
I wouldn't waste my time with the Moroso. Just get the Star mandrel and you will be happy. They are also real good at telling you exactly what ratio/pulleys you should be running as well. I like the star unit since I can use the captive nut on the end to turn to motor over without taking anything else off the front.
Re: vac pump Mandrel drive question??? [Re: n20mstr] #179257
12/31/08 01:05 AM
12/31/08 01:05 AM
AndyF Offline
AndyF  Offline
I didn't like the Moroso drive setup since it is so big and heavy but there really aren't many other choices available. I ended up building my own drive setup for the dry sump.
Re: vac pump Mandrel drive question??? [Re: AndyF] #179258
12/31/08 01:50 AM
12/31/08 01:50 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Unless they're making them now, star doesn't make a mandrel for a chrysler balancer, unless you have a Chevy front on it. The star mandrels are fantastic.
Re: vac pump Mandrel drive question??? [Re: n20mstr] #179259
12/31/08 02:03 AM
12/31/08 02:03 AM
AndyF Offline
AndyF  Offline
Here is the drive that I made. It is a spline drive rather than a shaft with a key but it works basically the same way. In this picture it is set up with just the one Gilmer pulley but it can be stacked with V groove pulleys as well. Peterson sells the spline drive stuff and they have spacers, pulleys, etc that all can be stacked in any order.
Re: vac pump Mandrel drive question??? [Re: AndyF] #179260
12/31/08 02:06 AM
12/31/08 02:06 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I have Petersen spline drive as well on mine. Very nice stuff.
Re: vac pump Mandrel drive question??? [Re: n20mstr] #179261
12/31/08 07:35 PM
12/31/08 07:35 PM
Colorado,U.S.A
4404dart Offline
4404dart  Offline
Colorado,U.S.A
You sly dog! Your up to no good! The Aerospace components drive looks good too, but I don't know if they have a chrysler drive? I have a couple chevy friends that have Musi motors, they both have enhanced 4 vane moroso pumps, that will pull all the vacuum you want. The star products look great too.
Re: vac pump Mandrel drive question??? [Re: 4404dart] #179262
12/31/08 07:49 PM
12/31/08 07:49 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
...The Aerospace components drive looks good too, but I don't know if they have a chrysler drive?
they do...
Re: vac pump Mandrel drive question??? [Re: n20mstr] #179263
12/31/08 07:56 PM
12/31/08 07:56 PM
long island new york
K
kingdust Offline
kingdust  Offline
K
CV products makes really nice pulleys and drives. there crank pulleys and mandrel drives are pin drive. you can build any configuration you can think of. check out there web site.that star products is top of the line though! they have an electric vacuum pump that the pro stock guys use, mounts on the floor in the car but its 1600.00.
LIFE IS A LESSON,YOU LEARN IT WHEN YOUR THROUGH!
Re: vac pump Mandrel drive question??? [Re: jughed] #179264
12/31/08 08:59 PM
12/31/08 08:59 PM
Colorado,U.S.A
4404dart Offline
4404dart  Offline
Colorado,U.S.A
Ya that's nice! How do you set valves etc? How do you rotate the motor?
Re: vac pump Mandrel drive question??? [Re: 4404dart] #179265
12/31/08 09:01 PM
12/31/08 09:01 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
starter butten
1.39 9.85 - 137 mph
