SB bracket racers, what spark plugs you running? #1789773
03/27/15 11:12 PM
03/27/15 11:12 PM
Weddington, N.C.
Streetwize Offline OP
Weddington, N.C.
Been running the NGK BP6ES which is comparable to the old N9Y, anything better and have you seen any advantage either way. Ran N9Y's 35 yrs ago so...,
Been running a 6AL and gap at .045
Thoughts?
Thanks!
Bobby
WIZE
In Car:
Re: SB bracket racers, what spark plugs you running? [Re: Streetwize] #1789774
03/27/15 11:26 PM
03/27/15 11:26 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I use autolite race plug 3911 for years. Haven't tried any other plug. Street- strip car running 9.50. I leave well enough alone.
Re: SB bracket racers, what spark plugs you running? [Re: Streetwize] #1789775
03/27/15 11:39 PM
03/27/15 11:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I was using the MP Champion 59 race plugs for years
in the race car.. 405 ci running 8.90s.. I run the
Autolite 3924r on my street/strip 416 ci..
Re: SB bracket racers, what spark plugs you running? [Re: MR_P_BODY] #1789776
03/27/15 11:49 PM
03/27/15 11:49 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
C59Y Champions or on occasion C61Y.
Re: SB bracket racers, what spark plugs you running? [Re: topside] #1789777
03/27/15 11:53 PM
03/27/15 11:53 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
40 years of racing with Autolite plugs for me. Currently running 3922's in my small block.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: SB bracket racers, what spark plugs you running? [Re: pittsburghracer] #1789778
03/28/15 12:07 AM
03/28/15 12:07 AM
off the grid
340B5 Offline
340B5  Offline
off the grid
NGK R5672A-8
Yeah, it's got a smallblock.
Re: SB bracket racers, what spark plugs you running? [Re: 340B5] #1789779
03/28/15 12:11 AM
03/28/15 12:11 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
AR3911.
Re: SB bracket racers, what spark plugs you running? [Re: justinp61] #1789780
03/28/15 12:21 AM
03/28/15 12:21 AM
San Antonio,TX
440W8 Duster Offline
San Antonio,TX
R5671A-9 in mine
70 Duster W8 motor.
1.29 60ft 5.79 1/8 at 120 mph
glide with 1.80 gear
@3170 lbs.
Re: SB bracket racers, what spark plugs you running? [Re: justinp61] #1789781
03/28/15 12:23 AM
03/28/15 12:23 AM
Weddington, N.C.
Weddington, N.C.
So these all look to be copper core race plugs, in these days of mega spark ignitions are the race specific plugs really an advantage they were when the copper core was important for maximizing the relatively weak spark of older ignition systems....I'm just wondering out loud really just in term of how copper deteriorates over time. Thoughts?
WIZE
In Car:
Re: SB bracket racers, what spark plugs you running? [Re: Streetwize] #1789782
03/28/15 12:32 AM
03/28/15 12:32 AM
Az
Crizila Offline
Crizila  Offline
Az
I like NGK's. Ran ZFR5F in my NA motor and R5671A-9 in my blower motor. Don't know about others, but per NGK, they come with a thread coating out of the box for use with aluminum heads. Don't have to coat with anti-seize, etc. I still use a light oil on the threads.
Fastest 300
Re: SB bracket racers, what spark plugs you running? [Re: Streetwize] #1789783
03/28/15 02:13 AM
03/28/15 02:13 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
I use 3923's in most. I back cut the ground electrode,set the gap around .035" . As far as durabilty,I pull them every month or 2 , re-gap and sharpen the electrodes,they do wear pretty quickly when making a bunch of passes.
Re: SB bracket racers, what spark plugs you running? [Re: Streetwize] #1789784
03/28/15 02:39 PM
03/28/15 02:39 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
Champion N6Y or RN6Y. $1.99 each at Oreilly Auto Parts. Run them for 1000 passes and put in new ones. Good as anything out there.
Re: SB bracket racers, what spark plugs you running? [Re: qwkmopardan] #1789785
03/30/15 12:31 AM
03/30/15 12:31 AM
Locomotion Offline
Locomotion  Offline
I've been using Accel 784 plugs. They take a 5/8" socket and fit my LA-X heads (Magnum type plugs) in my IHRA Dart as well as conventional Mopar small block heads which I have for a new NHRA 360 project.
I use to use N9YC and N7YC when they were easily found. But many years ago I found that the Champions seemed to rust if not run on a regular basis. I live in very humid Florida, but they didn't seem to be bad like that longer ago.
Re: SB bracket racers, what spark plugs you running? [Re: 440W8 Duster] #1789786
03/30/15 12:50 PM
03/30/15 12:50 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
R5671A-9 in mine
same here except a -7 heat range, these were suggested to me for use with E-85.
Re: SB bracket racers, what spark plugs you running? [Re: dartman366] #1789787
03/30/15 02:38 PM
03/30/15 02:38 PM
Renton Washington
Triple Threat Offline
Renton Washington
R5671A-9 in mine
Same here as well except -8's
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
