trans cooler preference #1788874
03/26/15 04:45 PM
03/26/15 04:45 PM
Mesa, AZ
cagebob1 Offline OP
cagebob1  Offline OP
Mesa, AZ
What type do you prefer? and why?
the heat sink type? or the traditional tube and fin style?
Re: trans cooler preference [Re: cagebob1] #1788875
03/26/15 05:41 PM
03/26/15 05:41 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
B & M supercooler (IIRC). tube and fin - 6 hoses. Worked well for the 727 behind a 850ish hp 572 more strip than street. Can be purchased with fan if my memory is good.
Re: trans cooler preference [Re: cagebob1] #1788876
03/26/15 05:52 PM
03/26/15 05:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Hayden builds MOST of the coolers on the market.. they
make the B&M super coolers also... I prefer the tube
and fin style
http://www.haydenauto.com/ROOT-Home/Content.aspx
Re: trans cooler preference [Re: cagebob1] #1788877
03/27/15 01:34 PM
03/27/15 01:34 PM
Mesa, AZ
cagebob1 Offline OP
cagebob1  Offline OP
Mesa, AZ
Wow! 157 views and only 2 replies? I guess there aren't many opinions on trans coolers. Thanks to those who replied
Re: trans cooler preference [Re: cagebob1] #1788878
03/27/15 06:09 PM
03/27/15 06:09 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
I have the B&M super cooler also..
5.53 @ 125 1/8th on the launch control..more left in her!
Re: trans cooler preference [Re: Eric] #1788879
03/27/15 06:14 PM
03/27/15 06:14 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
X2 on the supercooler.
Re: trans cooler preference [Re: rickraw] #1788880
03/27/15 06:27 PM
03/27/15 06:27 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
X3 on the Supercooler. the tube & fin is more restrictive, the supercooler is more efficient @ dispersing heat, especially with a fan connected to it
Re: trans cooler preference [Re: cagebob1] #1788881
03/27/15 06:46 PM
03/27/15 06:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
On this page you can see what the different coolers
are for and how much they cool.. and their purpose
EDIT
all these things are is a heat exchanger... the more fins
you have contacting the tubes the more heat is pulled
off.. until you start loosing the air flow across
the fins.. if the plate style is so good WHY isnt
a radiator made this way... the plate has its place
and its used for engine oil... the fins on a plate
are much thicker(less per inch).. a lot of times guys
use what they buy without really knowing what to buy
or were told that it works good... but if you dont
try BOTH you wont know which is better... I can say
I have tested both... and if you follow the Hayden
direction you wont be sorry.. by the way.. when I
say "tested" that was at work and on my own junk with
thermocouples on the inlet and outlet to measure the
temp drop.. if I still had my data I would post it
but I threw it away years ago
http://www.haydenauto.com/upload/HaydenAuto/Documents/Cat_Hayden/Transmission_Engine_Oil_Coolers.pdf
Re: trans cooler preference [Re: MR_P_BODY] #1788882
03/27/15 07:11 PM
03/27/15 07:11 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
""""""""Over 14 million transmissions fail every year, 9 out of 10 from
overheating. Every 20°F drop in operating temperature can double oil and equipment life"""""""
.....BUT ..... in a race car operation ... cooling the ATF too much kills the stall. I had a Bud that ran a J converter on a street car with as short a gear as a 2.9.....with ONLY a rad-tank-cooler .....
He never toasted the ATF in the many years he ran it....
Re: trans cooler preference [Re: dOc !] #1788883
03/27/15 07:27 PM
03/27/15 07:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
DO what you want... but I guess you dont warm up
your trans... when a trans has been warmed up in
the morning its good all day... so I'm sure it cooled
some... and I dont buy you idea if its tooo cold
Re: trans cooler preference [Re: MR_P_BODY] #1788884
03/27/15 07:48 PM
03/27/15 07:48 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
Not my idea P-Guy .... it was a long-ago bud that worked at CTC. And I ran several cars myself with some real small coolers. NEVER toasted any ATF myself either.
The last race car only I had a side mounted Hayden swirl-cooler .... the smallest they made. During one slow day at Detroit Dragway .... I made 33 passes IN A ROW ... non stop except for fuel
That was with a mild 383 in that Bantam roadster.
Re: trans cooler preference [Re: dOc !] #1788885
03/27/15 09:25 PM
03/27/15 09:25 PM
Mo.
racerx Offline
racerx  Offline
Mo.
x4
Re: trans cooler preference [Re: dOc !] #1788886
03/27/15 09:35 PM
03/27/15 09:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
By the way I have a J conv in my Rampage and with
OD I havent had a temp problem... thats with 9%
slippage in OD... but I have only run a few 150 mile runs
so far as my long distance runs.. about 600 miles
in the city.... that J stalls at 5000 in my ride..
I only have a Hayden and no radiator cooler
Re: trans cooler preference [Re: MR_P_BODY] #1788887
03/27/15 09:40 PM
03/27/15 09:40 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
I think I remember him saying that the temp(measured right off the converter) would spike at about 320 when staging ...
NOT sure what brand F-type ATF it was ... but it was a good name-brand.
Re: trans cooler preference [Re: MR_P_BODY] #1788888
03/27/15 09:42 PM
03/27/15 09:42 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
9% slip ....with how much OD and at what speed ?
Re: trans cooler preference [Re: dOc !] #1788889
03/27/15 09:44 PM
03/27/15 09:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
.69 at 75 mph
EDIT
thats at 2900 rpm
Re: trans cooler preference [Re: MR_P_BODY] #1788890
03/27/15 09:48 PM
03/27/15 09:48 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
.69 at 75 mph
Ooooops ....shoulda' asked .....what gear and tire height?
Re: trans cooler preference [Re: dOc !] #1788891
03/27/15 10:48 PM
03/27/15 10:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
.69 at 75 mph
Thats with a 295/55-15 with a 4.10 gear
Re: trans cooler preference [Re: MR_P_BODY] #1788892
03/27/15 11:55 PM
03/27/15 11:55 PM
Ohio
racerAL Offline
racerAL  Offline
Ohio
ive been shopping them for a week. I think ive decided to go with this kit from Derale.
http://www.jegs.com/i/Derale/259/12730K/10002/-1
-1967 Plymouth Satellite #3555
446 cid on E-85
best 1/4 et 10.577 @ 127.58
best 1/8 et 6.722 @ 100.68
best 60ft. 1.419
