Trans cooling lines hookup on a 22" 053 radiator? #1784144
03/20/15 03:26 AM
03/20/15 03:26 AM
Zombieland
Car Nut Online laugh2 OP
Zombieland
Can someone tell me the distance between the transmission cooling lines where they go into a 22" 053 radiator?
Re: Transmission cooling lines for a 22" 053 radiator? [Re: Car Nut] #1784145
03/20/15 11:15 AM
03/20/15 11:15 AM
WV
JohnH Offline
JohnH  Offline
WV
Best thing to do is order new prebent cooling lines,, They are not that expensive.. If that is what you need..
Re: Transmission cooling lines for a 22" 053 radiator? [Re: Car Nut] #1784146
03/20/15 02:45 PM
03/20/15 02:45 PM
Cincinnati, Ohio
cudaman67 Offline
cudaman67  Offline
Cincinnati, Ohio
I'll be over at the garage tomorrow....could measure mine and let you know. Larry
Re: Transmission cooling lines for a 22" 053 radiator? [Re: Car Nut] #1784147
03/20/15 06:00 PM
03/20/15 06:00 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
I have one here, 9 and 7/8 inches apart.
Re: Transmission cooling lines for a 22" 053 radiator? [Re: JohnH] #1784148
03/20/15 06:19 PM
03/20/15 06:19 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Just my opinion but...
I find it best to learn how to bend and flare the line.
Very easy and much cheaper.
Not sure what this would have to do with
the space between the lines though.
I'm wondering what the reason for the question would be.
I have mechanical Aptitude.
I can screw up anything.
Re: Transmission cooling lines for a 22" 053 radiator? [Re: bboogieart] #1784149
03/20/15 07:02 PM
03/20/15 07:02 PM
Zombieland
Zombieland
My car originally came with a 22" 053 radiator when new, but the previous owner changed it out. The transmission cooling lines had a 12" spread for the hookup on the radiator. I ordered a new 22" radiator from U.S. Radiator made for my car. I went to install it and the trans cooling hookup has a 10" spread where the passenger side runs into the harmonic balancer. I called Alex at U.S. Radiator and he says big blocks don't have a 12" spread, only a 10" spread.
Has anyone who bought a U.S. Radiator run into this problem?
Re: Transmission cooling lines for a 22" 053 radiator? [Re: Car Nut] #1784150
03/20/15 07:28 PM
03/20/15 07:28 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Thanx,
That clears up what your doing.
Sorry no help here.
I would have just bent up a new line.
However, I care not if it looks, or is, original.
Re: Transmission cooling lines for a 22" 053 radiator? [Re: bboogieart] #1784151
03/20/15 07:34 PM
03/20/15 07:34 PM
Zombieland
Zombieland
Sounds good thanks.
Thank you.
Thanx,
Sorry no help here.
I had Right Stuff custom bend me a set of lines out of SS which fits right into the radiator. The problem is where the passenger side out of the radiator runs into the harmonic balancer. I'll make it work.
Re: Transmission cooling lines for a 22" 053 radiator? [Re: Car Nut] #1784152
03/20/15 07:45 PM
03/20/15 07:45 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
(Quote)
Got ya.
Stainless is another subject.
A little tougher.
I'm sure you have it under control.
Re: Trans cooling lines hookup on a 22" 053 radiator? [Re: Car Nut] #1784153
03/21/15 09:20 PM
03/21/15 09:20 PM
Cincinnati, Ohio
cudaman67 Offline
cudaman67  Offline
Cincinnati, Ohio
Made it over to the garage today....mine is also a radiator from US radiators. Not sure of the number without finding the receipt, but it is in an A-body and the trans lines measure 10 inches center to center. I replaced my cooler lines with prefabbed ones , everything fit OK. Hope this helps. Larry
Re: Trans cooling lines hookup on a 22" 053 radiator? [Re: cudaman67] #1784154
03/21/15 11:29 PM
03/21/15 11:29 PM
Zombieland
Zombieland
Yes it helps, thanks. Do you have a fan shroud mounted to your 22" radiator, if so which one?
Thanks guys!
Re: Trans cooling lines hookup on a 22" 053 radiator? [Re: Car Nut] #1784155
03/22/15 11:14 AM
03/22/15 11:14 AM
Cincinnati, Ohio
cudaman67 Offline
cudaman67  Offline
Cincinnati, Ohio
Yes, I do have a fan shroud. Gave up trying to find a used one , and bought a new one from Mancini.
Looked it up, Mancini still sells. Looks like the price has gone up quite a bit since I bought mine. I paid 145, looks like the going price now is 175. It was a good fit, no problems with it. Larry
Re: Trans cooling lines hookup on a 22" 053 radiator? [Re: cudaman67] #1784156
03/22/15 02:50 PM
03/22/15 02:50 PM
Zombieland
Zombieland
Thanks.
