Re: Transmission cooling lines for a 22" 053 radiator?
[Re: Car Nut]
#1784150
03/20/15 07:28 PM
03/20/15 07:28 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Thanx, That clears up what your doing. Sorry no help here. I would have just bent up a new line. However, I care not if it looks, or is, original.
I have mechanical Aptitude. I can screw up anything.
[Re: bboogieart]
#1784151
03/20/15 07:34 PM
03/20/15 07:34 PM
Posts: 626 Zombieland
Car Nut
Zombieland
I'll be over at the garage tomorrow....could measure mine and let you know. Larry
Sounds good thanks.
I have one here, 9 and 7/8 inches apart.
Thank you.
I had Right Stuff custom bend me a set of lines out of SS which fits right into the radiator. The problem is where the passenger side out of the radiator runs into the harmonic balancer. I'll make it work.
[Re: Car Nut]
#1784152
03/20/15 07:45 PM
03/20/15 07:45 PM
bboogieart
Lost and Spaced
(Quote) I had Right Stuff custom bend me a set of lines out of SS which fits right into the radiator. Got ya. Stainless is another subject. A little tougher. I'm sure you have it under control.
Re: Trans cooling lines hookup on a 22" 053 radiator?
[Re: cudaman67]
#1784154
03/21/15 11:29 PM
03/21/15 11:29 PM
Car Nut
Zombieland
Made it over to the garage today....mine is also a radiator from US radiators. Not sure of the number without finding the receipt, but it is in an A-body and the trans lines measure 10 inches center to center. I replaced my cooler lines with prefabbed ones , everything fit OK. Hope this helps. Larry
Yes it helps, thanks. Do you have a fan shroud mounted to your 22" radiator, if so which one? Thanks guys!
