Re: Srt4 will not move [Re: Supercuda] #1781876
03/19/15 01:28 PM
03/19/15 01:28 PM
ME
79machocharger Offline OP
ME
So it looks like I'll be removing a trans this weekend. It was supposed to have had a new stage three clutch in it I guess we'll see.
Re: Srt4 will not move [Re: 79machocharger] #1781877
03/19/15 03:18 PM
03/19/15 03:18 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Allow me to preface this with the statement that I know almost nothing about SRT-4's.
Years ago I had a neighbor that had a Honda CVCC that would not move. Supposedly a friend changed the clutch and it did not help. Since I owed her some favors I told her I'd look at it. The clutch in that car was hydraulically operated, but did have provisions for adjustment at the fork. That was the only problem and it took me maybe 5 minutes to fix it. It had sat for years prior.
Never assume the last "mechanic" in there had a clue.
Don't be the exception.
Re: Srt4 will not move [Re: Supercuda] #1781878
03/20/15 01:53 AM
03/20/15 01:53 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
If it was the clutch hydraulic slave cyl not working or the cable broke he could not put the trans in any gear with the eng running as it would be like putting and normal woking manual trans car in gear without pushing the clutch in. Which as we know is not going to happen. But I am sure the owner as we all do is appreciate your input.
Let us know how you make out. Ron
Re: Srt4 will not move [Re: 383man] #1781879
03/20/15 09:17 PM
03/20/15 09:17 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
If the clutch is engaged and the wheel is turning,
you should not be able to grab the wheel,
let alone stop it.
Your trouble is most definately clutch related.
I would first try to adjust it.
If that is a no go you probably need a new clutch.
Never believe what the seller told you, unless a trusted friend.
Good luck and let us know how things turn out.
I have mechanical Aptitude.
I can screw up anything.
Re: Srt4 will not move [Re: bboogieart] #1781880
03/21/15 02:00 PM
03/21/15 02:00 PM
ME
ME
Got the tranny out and I can't see any issues with it.
Re: Srt4 will not move [Re: 79machocharger] #1781881
03/21/15 02:03 PM
03/21/15 02:03 PM
ME
ME
Clutch, how can you tell if the clutch is bad by looking at it
Re: Srt4 will not move [Re: 79machocharger] #1781882
03/21/15 02:32 PM
03/21/15 02:32 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
you have to unbolt it from the engine side of the flywheel
Re: Srt4 will not move [Re: AARCONV] #1781883
03/21/15 05:04 PM
03/21/15 05:04 PM
Far Northeast.
mymcodebee Offline
mymcodebee  Offline
Far Northeast.
Update. We're in garage. Pulled trans. When turning input shaft on trans while
in gear we can put an axle in and hold it in place. Sound like a trans issue?
Re: Srt4 will not move [Re: mymcodebee] #1781884
03/21/15 07:56 PM
03/21/15 07:56 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
diff
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Srt4 will not move [Re: 3hundred] #1781885
03/21/15 08:04 PM
03/21/15 08:04 PM
kalispell montana
jwilson 61 Offline
jwilson 61  Offline
kalispell montana
You need both axles in and held to tell if it is internal the differential will allow the spider gear that is not engaged to an axle to spin and you wont be able to tell without both axles engaged
70 cuda 440 6bbl Auto with a dana 60
68 road runner QQ1 383 auto
1970 6 barrel 4 speed Superbird FY1 number matching
15 Challenger 6.4 SRT pearl White 6 Speed
72 Cuda 440 5 speed
71 Road Runner 440 4 speed
Re: Srt4 will not move [Re: jwilson 61] #1781886
03/21/15 11:48 PM
03/21/15 11:48 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
05s have the Quaife diff, so it may have broken worm gears too
Are ya going to part the car? If so I have a list
Re: Srt4 will not move [Re: 383man] #1781887
03/22/15 01:07 PM
03/22/15 01:07 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Reading comprehension is not your forte is it?
Go back and reread it, pay very close attention to the very last line I wrote. Ask your mommy for help with the big words.
If you still cannot figure it out the first part was an allegory with the very last line the point of it. Again, mommy can help with the big words.
Re: Srt4 will not move [Re: A990] #1781888
03/22/15 03:26 PM
03/22/15 03:26 PM
ME
ME
Alright stuck both axles In the transmission and rotated the input shaft by hand and both axles rotate the same way(correct for lsd trans). The weird part is I can grab ahold of the input shaft and hold it still and still spins the axle? I can even spin the axles in different directions by hand. Should I be able to do this? Really appreciate the help guys. I tried getting onto a srt4 forum for some reason it's not letting me be a member.
Re: Srt4 will not move [Re: 79machocharger] #1781889
03/23/15 01:10 AM
03/23/15 01:10 AM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
One other poster with the bad third gear, You are going to need to buy a transmission. All the parts to rebuild the transmission are either on back order or no longer serviced. Third gear pop out is a common problem with these transmission and that is why we have stocked up on them for the three cars we have. Now the poster has to tell a little more on what he has tried with the axles. Is it in gear or not when testing. Will it go into gear while running and still will not move. Will it go into gear when it is not running. Post all what you have done on one post.
1971 HEMI E BODY REGISTRY
Re: Srt4 will not move [Re: hemicar1971] #1781890
03/23/15 01:31 AM
03/23/15 01:31 AM
Far Northeast.
mymcodebee Offline
mymcodebee  Offline
Far Northeast.
We found the issue today. He has some pics and will post them when he gets out of work.
It is a broken shift selector.
It looks exactly like this broken one.
Re: Srt4 will not move [Re: mymcodebee] #1781891
03/23/15 01:20 PM
03/23/15 01:20 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
Common problem ..but it should not affect other gears..
Re: Srt4 will not move [Re: AARCONV] #1781892
03/23/15 08:05 PM
03/23/15 08:05 PM
Milwaukee, WI
moparjimbo Offline
moparjimbo  Offline
Milwaukee, WI
Wierd who said cable/bushings or shift selector?
<-----this guy
1996 Viper GTS - UGR Twin Turbo 1500RWHP, 9.02 @ 167 on pump gas and DOT tire
1973 Challenger - 572 Indy Hemi 860HP
1975 Trailduster Convertible, 440
1967 Plymouth Fury Police Pursuit 2DR 505 Stroker
2004 Neon SRT4 modded
www.milwaukeemopar.com
Re: Srt4 will not move [Re: moparjimbo] #1781893
03/24/15 07:06 PM
03/24/15 07:06 PM
Milwaukee, WI
moparjimbo Offline
moparjimbo  Offline
Milwaukee, WI
Also for future reference, this guy - Tim Zimmer - is local to me and does nothing but rebuild Getrag transmissions for DSM/Talon/Eclipse/Laser, Stealth/3000GT, and SRT4s. He can get parts, knows what he is doing, and is very reasonably priced.
www.tmzperformance.com
Re: Srt4 will not move [Re: moparjimbo] #1781894
03/25/15 01:50 PM
03/25/15 01:50 PM
ME
ME
Thanks guys really appreciate all the help. Hope to have it all back in this weekend. Needed to open it up to get the broken tab off the selector laying inthe bottom of casing. Gears didn't get damaged so that's good. Turned out to be a cheap fix.
