Re: Srt4 will not move
[Re: Supercuda]
#1781878
03/20/15 01:53 AM
03/20/15 01:53 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
So it looks like I'll be removing a trans this weekend. It was supposed to have had a new stage three clutch in it I guess we'll see.
Allow me to preface this with the statement that I know almost nothing about SRT-4's.
Years ago I had a neighbor that had a Honda CVCC that would not move. Supposedly a friend changed the clutch and it did not help. Since I owed her some favors I told her I'd look at it. The clutch in that car was hydraulically operated, but did have provisions for adjustment at the fork. That was the only problem and it took me maybe 5 minutes to fix it. It had sat for years prior.
Never assume the last "mechanic" in there had a clue.
If it was the clutch hydraulic slave cyl not working or the cable broke he could not put the trans in any gear with the eng running as it would be like putting and normal woking manual trans car in gear without pushing the clutch in. Which as we know is not going to happen. But I am sure the owner as we all do is appreciate your input.
Let us know how you make out. Ron
[Re: 383man]
#1781879
03/20/15 09:17 PM
03/20/15 09:17 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
If the clutch is engaged and the wheel is turning, you should not be able to grab the wheel, let alone stop it. Your trouble is most definately clutch related. I would first try to adjust it. If that is a no go you probably need a new clutch. Never believe what the seller told you, unless a trusted friend. Good luck and let us know how things turn out.
I have mechanical Aptitude. I can screw up anything.
[Re: 3hundred]
#1781885
03/21/15 08:04 PM
03/21/15 08:04 PM
Posts: 125 kalispell montana
jwilson 61
kalispell montana
You need both axles in and held to tell if it is internal the differential will allow the spider gear that is not engaged to an axle to spin and you wont be able to tell without both axles engaged
70 cuda 440 6bbl Auto with a dana 60 68 road runner QQ1 383 auto 1970 6 barrel 4 speed Superbird FY1 number matching 15 Challenger 6.4 SRT pearl White 6 Speed 72 Cuda 440 5 speed 71 Road Runner 440 4 speed
[Re: jwilson 61]
#1781886
03/21/15 11:48 PM
03/21/15 11:48 PM
Posts: 2,735 541 slobovia
A990
541 slobovia
05s have the Quaife diff, so it may have broken worm gears too
Are ya going to part the car? If so I have a list
[Re: 79machocharger]
#1781889
03/23/15 01:10 AM
03/23/15 01:10 AM
Posts: 5,122 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
One other poster with the bad third gear, You are going to need to buy a transmission. All the parts to rebuild the transmission are either on back order or no longer serviced. Third gear pop out is a common problem with these transmission and that is why we have stocked up on them for the three cars we have. Now the poster has to tell a little more on what he has tried with the axles. Is it in gear or not when testing. Will it go into gear while running and still will not move. Will it go into gear when it is not running. Post all what you have done on one post.
1971 HEMI E BODY REGISTRY
[Re: AARCONV]
#1781892
03/23/15 08:05 PM
03/23/15 08:05 PM
Posts: 197 Milwaukee, WI
moparjimbo
Milwaukee, WI
Wierd who said cable/bushings or shift selector? <-----this guy
1996 Viper GTS - UGR Twin Turbo 1500RWHP, 9.02 @ 167 on pump gas and DOT tire 1973 Challenger - 572 Indy Hemi 860HP 1975 Trailduster Convertible, 440 1967 Plymouth Fury Police Pursuit 2DR 505 Stroker 2004 Neon SRT4 modded www.milwaukeemopar.com
[Re: moparjimbo]
#1781893
03/24/15 07:06 PM
03/24/15 07:06 PM
moparjimbo
Milwaukee, WI
Also for future reference, this guy - Tim Zimmer - is local to me and does nothing but rebuild Getrag transmissions for DSM/Talon/Eclipse/Laser, Stealth/3000GT, and SRT4s. He can get parts, knows what he is doing, and is very reasonably priced. www.tmzperformance.com
