Re: What brand of wire connectors do you use? [Re: John_Kunkel] #1769295
03/04/15 08:56 PM
03/04/15 08:56 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Soldering and heat shrink butt connectors are dandy on the bench but try it lying on your back under the dash.
I have, why? Because I do not want to do it again.
I bought my daughter a vehicle and the donkey who owned it before us put in an aftermarket radio. Rather than spring for the $10 adapter to plug into the OEM wiring he cut off the connector, twisted the wires together and electrical taped them, then left the single DIN radio hanging loose in a double DIN opening. Guess would crimped, soldered and heat shrunk that mess?
I have since decided that I will never buy another used vehicle if it has an aftermarket radio in it or a "cold air intake" on it.
Don't be the exception.
Re: What brand of wire connectors do you use? [Re: Supercuda] #1769296
03/05/15 05:15 AM
03/05/15 05:15 AM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
There was a time when there was no such thing as the plug and play connector for the aftermarket radios.
Re: What brand of wire connectors do you use? [Re: John_Kunkel] #1769297
03/05/15 05:48 AM
03/05/15 05:48 AM
San Diego
Instigate Offline
Instigate  Offline
San Diego
I've had to solder in some strange positions and yea it's not ideal but just like welding, it is possible if you know what you're doing.
Re: What brand of wire connectors do you use? [Re: Instigate] #1769298
03/05/15 10:27 PM
03/05/15 10:27 PM
Here and now
jeebis44 Offline
jeebis44  Offline
Here and now
Posiloks...
Re: What brand of wire connectors do you use? [Re: hp383] #1769299
03/05/15 10:37 PM
03/05/15 10:37 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
It's a 97 Exploder, that time was before then.
Re: What brand of wire connectors do you use? [Re: 70Duster] #1769300
03/05/15 10:53 PM
03/05/15 10:53 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
These are still made in south central Pennsylvania by TE Connectivity. Tyco International bought AMP in 1999. The tradename "AMP" remains. A spinoff years later changed the company name to Tyco Electronics which later became TE Connectivity. These are still made on some of the original machines that were designed and built in the 50's (with some major safety and productivity improvements) and are still specified in many aircraft and military applications.
Varies, but Anchor brand is what I'll buy if I can - they're for marine use - and there used to be boat supply in town. The copper in marine wire is tinned, so I prefer that too (for its corrosion resistance). Again, local availability is a dominating reason. If industrial quality was easy access, and I didn't need to buy 100 at time, then the AMPs or some of the other newer connectors would be on the short list.
Re: What brand of wire connectors do you use? [Re: Mattax] #1769301
03/05/15 11:32 PM
03/05/15 11:32 PM
NoVa
E
ebodyseast Offline
ebodyseast  Offline
E
NoVa
Napa and Autozone in my area have these butt connectors with the solder ring in the center and also the style that are both crimped and soldered
