Re: What brand of wire connectors do you use?
[Re: John_Kunkel]
#1769279
03/02/15 09:22 PM
03/02/15 09:22 PM
Posts: 197 Milwaukee, WI
moparjimbo
Milwaukee, WI
I use the GM/Packard Weatherpack - they are real common, sealed, work well, and can get em on ebay amazon jegs summit in big kits with multiple various connectors for cheap. When I worked at Komatsu/Dresser/International Harvestor we used em on a lot of our construction equipment and used em all the time in the shop when wiring up test setups. Some people prefer the Deutsch but I think they are more expensive and harder to get.
1996 Viper GTS - UGR Twin Turbo 1500RWHP, 9.02 @ 167 on pump gas and DOT tire 1973 Challenger - 572 Indy Hemi 860HP 1975 Trailduster Convertible, 440 1967 Plymouth Fury Police Pursuit 2DR 505 Stroker 2004 Neon SRT4 modded www.milwaukeemopar.com
[Re: feets]
#1769281
03/02/15 10:43 PM
03/02/15 10:43 PM
Posts: 2,592 None
71rm23
None
I have picked up a few from work when I was doing something important. The Mercedes connectors have solder in them. No doubt other companies make them but I haven't searched for any.
If you need something like what Feets posted, its good stuff. Been using this kind for many uses in aviation for years
[Re: ahy]
#1769283
03/02/15 11:44 PM
03/02/15 11:44 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
When I learned soldering in the Navy I was taught that solder is for a good electrical connection and a crimp is for a good mechanical connection, never substitute one for the other.
I know Chrysler just used crimps but they were building to a price, you shouldn't be.
[Re: hp383]
#1769287
03/03/15 10:02 AM
03/03/15 10:02 AM
Posts: 10,740 North Dakota
6PakBee
North Dakota
I use a common crimp connecter, solder it, and then cover it with the adhesive type of heat shrink tubing. Low cost, waterproof, and ultimate flexibility.
[Re: John_Kunkel]
#1769290
03/03/15 08:02 PM
03/03/15 08:02 PM
Posts: 1,642 PA
70Duster
PA
The AMP connectors I posted are translucent, you can look into them after crimping and see end of the (stripped to proper length) wire. Crimping using the proper crimper also crimps the insulation which provides strain relief for both the wire and its insulation.
These are still made in south central Pennsylvania by TE Connectivity. Tyco International bought AMP in 1999. The tradename "AMP" remains. A spinoff years later changed the company name to Tyco Electronics which later became TE Connectivity. These are still made on some of the original machines that were designed and built in the 50's (with some major safety and productivity improvements) and are still specified in many aircraft and military applications.
[Re: Instigate]
#1769292
03/04/15 05:44 PM
03/04/15 05:44 PM
Posts: 25,899 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Soldering and heat shrink butt connectors are dandy on the bench but try it lying on your back under the dash.
