Re: why so difficult to find dome pistons for sb?
[Re: HotRodDave]
#1763593
02/27/15 02:55 PM
02/27/15 02:55 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
Oh and of all the shelf stock pistons diamond tend to be among the heaviest, other than that they are real nice pistons and we do use them, I am putting a set in my own 410 right now but they are the heaviest flat top I have used in a 4 inch SB.
[Re: mopar dave]
#1763596
02/27/15 03:15 PM
02/27/15 03:15 PM
Posts: 52,972 Romeo MI
MR_P_BODY
thought I would put that out there to get others opinions on the comment. heres another of there comments, "girdles are for fat chicks" I no longer use this shop
I know the shop also.. I quit using them.. as some others have done ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Monte_Smith]
#1763599
02/27/15 05:19 PM
02/27/15 05:19 PM
Posts: 11,729 Portage,michigan
B3422W5
Portage,michigan
If my desired compression ratio, came down to milling a new set of heads .040 or ponying up extra for custom pistons, that's a no brainer for me. I'm not cutting my head until I HAVE to. You can always cut, you can't put it back
Monte
Exactly ...... Then you likely have to cut the intake as well , deck isnt as thick, more chance with 10 bolts pitching a head gasket.
