Re: why so difficult to find dome pistons for sb?
[Re: mopar dave]
#1763574
02/26/15 02:14 PM
02/26/15 02:14 PM
Posts: 429 Washington
skrews
Washington
Ross and Icon have dome pistons for the SBM. Not sure if Icon has them for 4" stroke though.
[Re: skrews]
#1763575
02/26/15 02:19 PM
02/26/15 02:19 PM
Posts: 656 Florida
CJD AUTOMOTIVE
That's when you turn that rod journal to 2.100" and open up the vast world of SB Chevy piston/rod combos.
Craig Scholl CJD Automotive, LLC Jacksonville, FL www.CJDAUTOMOTIVE.com904-400-1802 "I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
[Re: sleepyhead416]
#1763579
02/26/15 07:28 PM
02/26/15 07:28 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
This is kind of what I was going to say. It seems with a little milling on some heads you can get tons of compresison. And for what its worth, I just used a set of mahles for the first time in a stroker and was very impressed with what I saw, very light, very affordable (comes with rings for less than others did without) hard anodized over entir piston and teflon anti friction coating on the skirts.... I am building a 410 for my 99 RT dak and trying to figure out how to not end up with 12 to 1.
[Re: mopar dave]
#1763583
02/26/15 11:04 PM
02/26/15 11:04 PM
Posts: 11,719 Portage,michigan
B3422W5
Portage,michigan
I ran a dome cp... Thought they were great pistons
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#1763584
02/26/15 11:11 PM
02/26/15 11:11 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
. With your w5s ?
[Re: B3422W5]
#1763586
02/27/15 12:43 AM
02/27/15 12:43 AM
Posts: 1,390 CA.
RAY1969CARS
CA.
. With your w5s ?
Yes
do you have any pictures of those Pistons ??
[Re: mopar dave]
#1763587
02/27/15 02:25 AM
02/27/15 02:25 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
thought I had this figured out with the wiseco k0011b4 dome. wont work, made for standard head. gonna be custom deal with wiseco. mahle has nothing and a custom piston thru them is about $1600/set. diamond has nothing either. looking for something to make about 13.5:1 with a 4" stroke.
Diamond and most others will build you whatever you want. You are only a chamber mold away from getting EXACTLY what you want
Monte
[Re: mopar dave]
#1763589
02/27/15 09:02 AM
02/27/15 09:02 AM
Posts: 1,784 PA
W5DART66
PA
I understand that. looking for a shelf piston. this is somewhat of a budget build if I can keep it that way. been told the diamonds are clunkers by a well known mopar shop in Detroit. the wiseco dome shelf piston for $553 was what I was looking for. bummer it wont work.
Run far away from what ever shop said diamond was a clunker they are lost!
[Re: W5DART66]
#1763590
02/27/15 09:13 AM
02/27/15 09:13 AM
Quicktree
lol no kidding
[Re: mopar dave]
#1763592
02/27/15 02:35 PM
02/27/15 02:35 PM
HotRodDave
Kalispell Mt.
if .040 is too heavy you need new heads. A flat top gives you best flame travel, lightest piston, least surface area to absorb heat... if you can figure a way to make it happen you really should
