why so difficult to find dome pistons for sb? #1763573
02/26/15 01:56 PM
02/26/15 01:56 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
thought I had this figured out with the wiseco k0011b4 dome. wont work, made for standard head. gonna be custom deal with wiseco. mahle has nothing and a custom piston thru them is about $1600/set. diamond has nothing either. looking for something to make about 13.5:1 with a 4" stroke.
Re: why so difficult to find dome pistons for sb? [Re: mopar dave] #1763574
02/26/15 02:14 PM
02/26/15 02:14 PM
Washington
skrews Offline
skrews  Offline
Washington
Ross and Icon have dome pistons for the SBM. Not sure if Icon has them for 4" stroke though.
Re: why so difficult to find dome pistons for sb? [Re: skrews] #1763575
02/26/15 02:19 PM
02/26/15 02:19 PM
CJD AUTOMOTIVE Offline
That's when you turn that rod journal to 2.100" and open up the vast world of SB Chevy piston/rod combos.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
www.CJDAUTOMOTIVE.com
904-400-1802
"I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
Re: why so difficult to find dome pistons for sb? [Re: mopar dave] #1763576
02/26/15 04:44 PM
02/26/15 04:44 PM
CA.
RAY1969CARS Offline
RAY1969CARS  Offline
CA.
What heads Do you have ???
Re: why so difficult to find dome pistons for sb? [Re: RAY1969CARS] #1763577
02/26/15 05:27 PM
02/26/15 05:27 PM
, PA
sleepyhead416 Offline
, PA
My Diamond flat top Came out to 13.8 w/55 cc head 4"stroke
Re: why so difficult to find dome pistons for sb? [Re: sleepyhead416] #1763578
02/26/15 05:34 PM
02/26/15 05:34 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I have 13.0 with flat top's and a 59 cc chamber with a 4" stroke and Probe pistons
Re: why so difficult to find dome pistons for sb? [Re: sleepyhead416] #1763579
02/26/15 07:28 PM
02/26/15 07:28 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
This is kind of what I was going to say.
It seems with a little milling on some heads you can get tons of compresison.
And for what its worth, I just used a set of mahles for the first time in a stroker and was very impressed with what I saw, very light, very affordable (comes with rings for less than others did without) hard anodized over entir piston and teflon anti friction coating on the skirts....
I am building a 410 for my 99 RT dak and trying to figure out how to not end up with 12 to 1.
Re: why so difficult to find dome pistons for sb? [Re: RAY1969CARS] #1763580
02/26/15 10:33 PM
02/26/15 10:33 PM
Mt Morris Michigan
Mt Morris Michigan
indy 360-1. to get 13.7 I would have to heavily mill head about .040" to get 54cc chamber. don't know if they can go that far.
Re: why so difficult to find dome pistons for sb? [Re: sleepyhead416] #1763581
02/26/15 10:35 PM
02/26/15 10:35 PM
Mt Morris Michigan
Mt Morris Michigan
what cc are the valve notches? most flat tops are 5cc.
Re: why so difficult to find dome pistons for sb? [Re: HotRodDave] #1763582
02/26/15 10:50 PM
02/26/15 10:50 PM
Mt Morris Michigan
Mt Morris Michigan
mahle flat top was the piston I had in mind for the last few yrs, but would have to mill the crap out of my indy heads to get the compression I want. now looking at wiseco custom or CP with a dome.
Re: why so difficult to find dome pistons for sb? [Re: mopar dave] #1763583
02/26/15 11:04 PM
02/26/15 11:04 PM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
I ran a dome cp... Thought they were great pistons
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: why so difficult to find dome pistons for sb? [Re: B3422W5] #1763584
02/26/15 11:11 PM
02/26/15 11:11 PM
CA.
RAY1969CARS Offline
RAY1969CARS  Offline
CA.
. With your w5s ?
Re: why so difficult to find dome pistons for sb? [Re: RAY1969CARS] #1763585
02/26/15 11:49 PM
02/26/15 11:49 PM
Portage,michigan
Portage,michigan
. With your w5s ?
Yes
1.41 best 60 foot
6.60 at 103.90 1/8
Re: why so difficult to find dome pistons for sb? [Re: B3422W5] #1763586
02/27/15 12:43 AM
02/27/15 12:43 AM
CA.
RAY1969CARS Offline
RAY1969CARS  Offline
CA.
. With your w5s ?
Yes
do you have any pictures of those Pistons ??
Re: why so difficult to find dome pistons for sb? [Re: mopar dave] #1763587
02/27/15 02:25 AM
02/27/15 02:25 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Diamond and most others will build you whatever you want. You are only a chamber mold away from getting EXACTLY what you want
Monte
Re: why so difficult to find dome pistons for sb? [Re: Monte_Smith] #1763588
02/27/15 02:40 AM
02/27/15 02:40 AM
Mt Morris Michigan
Mt Morris Michigan
I understand that. looking for a shelf piston. this is somewhat of a budget build if I can keep it that way. been told the diamonds are clunkers by a well known mopar shop in Detroit. the wiseco dome shelf piston for $553 was what I was looking for. bummer it wont work.
Re: why so difficult to find dome pistons for sb? [Re: mopar dave] #1763589
02/27/15 09:02 AM
02/27/15 09:02 AM
PA
W5DART66 Offline
W5DART66  Offline
PA
Run far away from what ever shop said diamond was a clunker they are lost!
Re: why so difficult to find dome pistons for sb? [Re: W5DART66] #1763590
02/27/15 09:13 AM
02/27/15 09:13 AM
Q
Quicktree Offline
Quicktree  Offline
Q
lol no kidding
Re: why so difficult to find dome pistons for sb? [Re: W5DART66] #1763591
02/27/15 12:02 PM
02/27/15 12:02 PM
Mt Morris Michigan
Mt Morris Michigan
thought I would put that out there to get others opinions on the comment. heres another of there comments, "girdles are for fat chicks"
I no longer use this shop
Re: why so difficult to find dome pistons for sb? [Re: mopar dave] #1763592
02/27/15 02:35 PM
02/27/15 02:35 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
if .040 is too heavy you need new heads.
A flat top gives you best flame travel, lightest piston, least surface area to absorb heat... if you can figure a way to make it happen you really should
