Re: why so difficult to find dome pistons for sb?
[Re: mopar dave]
#1763574
02/26/15 02:14 PM
02/26/15 02:14 PM
Posts: 429 Washington
skrews
Washington
Ross and Icon have dome pistons for the SBM. Not sure if Icon has them for 4" stroke though.
[Re: skrews]
#1763575
02/26/15 02:19 PM
02/26/15 02:19 PM
Posts: 656 Florida
CJD AUTOMOTIVE
That's when you turn that rod journal to 2.100" and open up the vast world of SB Chevy piston/rod combos.
Craig Scholl CJD Automotive, LLC Jacksonville, FL www.CJDAUTOMOTIVE.com904-400-1802 "I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
[Re: sleepyhead416]
#1763579
02/26/15 07:28 PM
02/26/15 07:28 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
This is kind of what I was going to say. It seems with a little milling on some heads you can get tons of compresison. And for what its worth, I just used a set of mahles for the first time in a stroker and was very impressed with what I saw, very light, very affordable (comes with rings for less than others did without) hard anodized over entir piston and teflon anti friction coating on the skirts.... I am building a 410 for my 99 RT dak and trying to figure out how to not end up with 12 to 1.
[Re: mopar dave]
#1763583
02/26/15 11:04 PM
02/26/15 11:04 PM
Posts: 11,729 Portage,michigan
B3422W5
Portage,michigan
I ran a dome cp... Thought they were great pistons
[Re: B3422W5]
#1763584
02/26/15 11:11 PM
02/26/15 11:11 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
. With your w5s ?
[Re: B3422W5]
#1763586
02/27/15 12:43 AM
02/27/15 12:43 AM
Posts: 1,390 CA.
RAY1969CARS
CA.
. With your w5s ?
Yes
do you have any pictures of those Pistons ??
[Re: mopar dave]
#1763587
02/27/15 02:25 AM
02/27/15 02:25 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
thought I had this figured out with the wiseco k0011b4 dome. wont work, made for standard head. gonna be custom deal with wiseco. mahle has nothing and a custom piston thru them is about $1600/set. diamond has nothing either. looking for something to make about 13.5:1 with a 4" stroke.
Diamond and most others will build you whatever you want. You are only a chamber mold away from getting EXACTLY what you want
Monte
[Re: mopar dave]
#1763589
02/27/15 09:02 AM
02/27/15 09:02 AM
Posts: 1,784 PA
W5DART66
PA
I understand that. looking for a shelf piston. this is somewhat of a budget build if I can keep it that way. been told the diamonds are clunkers by a well known mopar shop in Detroit. the wiseco dome shelf piston for $553 was what I was looking for. bummer it wont work.
Run far away from what ever shop said diamond was a clunker they are lost!
[Re: W5DART66]
#1763590
02/27/15 09:13 AM
02/27/15 09:13 AM
Quicktree
lol no kidding
[Re: mopar dave]
#1763592
02/27/15 02:35 PM
02/27/15 02:35 PM
HotRodDave
Kalispell Mt.
if .040 is too heavy you need new heads. A flat top gives you best flame travel, lightest piston, least surface area to absorb heat... if you can figure a way to make it happen you really should
